Light and Dark mode automation
I feel like I can’t find a proper answer to this, but I want to create an automation that changes between light and dark mode based on the sun. I don’t know if this is a bug or simply not possible, but when I create an automation that sets the theme, it will only set colors. I created a theme that has a light mode and a dark mode and created an automation that sets that theme and the mode. Setting the theme only works if I’m setting the mode to light.
So, if I have theme1 set through a script and dark mode enabled through my profile, and use a script or automation to set it to theme2, it only sets if I tell it to choose light mode. If I do theme2 dark mode–even if I’m currently set to dark mode–it won’t work.
This is really annoying because on my fire tablet, selecting auto in the profile doesn’t work. So that’s why I’d like to have the automation.
Auto means what the OS does. So is the tablet set to auto as well?
The tablet doesn’t have auto. It doesn’t have OS light and dark mode. That’s why auto doesn’t work.
