[{"id":"af7a5936.5847c8","type":"tab","label":"Time Of Day","disabled":false,"info":""},{"id":"3ac1b9df.e32dd6","type":"inject","z":"af7a5936.5847c8","name":"","topic":"current_time","payload":"","payloadType":"date","repeat":"60","crontab":"","once":false,"onceDelay":0.1,"x":115,"y":892.2858457565308,"wires":[["b8089dad.0bb29"]]},{"id":"e00c2433.d063b8","type":"server-state-changed","z":"af7a5936.5847c8","name":"Coffee Machine Time Off","server":"48eefced.ce1b34","entityidfilter":"input_number.coffee_machine_time_off","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"x":121,"y":113,"wires":[["bff71fbd.f859b"]]},{"id":"c00b3dfd.30acb","type":"server-state-changed","z":"af7a5936.5847c8","name":"Lamp lighting time off","server":"48eefced.ce1b34","entityidfilter":"input_number.lamp_lighting_time_off","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"x":112,"y":197,"wires":[["bff71fbd.f859b"]]},{"id":"4006a3ab.c1046c","type":"server-state-changed","z":"af7a5936.5847c8","name":"Heating Time off","server":"48eefced.ce1b34","entityidfilter":"input_number.heating_time_off","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"x":94,"y":155,"wires":[["bff71fbd.f859b"]]},{"id":"a30c601d.127fa","type":"server-state-changed","z":"af7a5936.5847c8","name":"Morning Time End","server":"48eefced.ce1b34","entityidfilter":"input_number.morning_time_end","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"x":105,"y":71,"wires":[["bff71fbd.f859b"]]},{"id":"3b1b5153.26560e","type":"server-state-changed","z":"af7a5936.5847c8","name":"Morning Time Start","server":"48eefced.ce1b34","entityidfilter":"input_number.morning_time_start","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"x":103,"y":26,"wires":[["bff71fbd.f859b"]]},{"id":"bff71fbd.f859b","type":"function","z":"af7a5936.5847c8","name":"Save HA TImes to Flow variables.","func":"var time = 0;\nif (Number(msg.payload) < 25)\n time = Number(msg.payload + \"00\");\nelse\n time = Number(msg.payload);\n\n\nvar topic = msg.topic.split(\".\")[1];\nflow.set(msg.topic,msg.payload);\nflow.set(topic,time);\nnode.warn(topic + ' is set to ' + msg.payload + \" Full time set to \" + String(time)); \nreturn msg;","outputs":1,"noerr":0,"x":1034.3929290771484,"y":129.9285764694214,"wires":[["c2efe21a.2a18e"]]},{"id":"2e14383a.70a2f8","type":"server-state-changed","z":"af7a5936.5847c8","name":"Sunset Minus One","server":"48eefced.ce1b34","entityidfilter":"sensor.next_sunset","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"x":102,"y":252,"wires":[["6219dd86.5ba2f4"]]},{"id":"6219dd86.5ba2f4","type":"moment","z":"af7a5936.5847c8","name":"","topic":"sensor.next_sunset","input":"","inputType":"msg","inTz":"Pacific/Auckland","adjAmount":"1","adjType":"hours","adjDir":"subtract","format":"HHmm","locale":"POSIX","output":"payload","outputType":"msg","outTz":"Pacific/Auckland","x":577.8571472167969,"y":253.285737991333,"wires":[["bff71fbd.f859b"]]},{"id":"800cab20.6e24e8","type":"switch","z":"af7a5936.5847c8","name":"Time Decision","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"morning_time_start","vt":"flow","v2":"morning_time_end","v2t":"flow"},{"t":"btwn","v":"morning_time_end","vt":"flow","v2":"coffee_machine_time_off","v2t":"flow"},{"t":"btwn","v":"morning_time_end","vt":"num","v2":"sunset_minus_one","v2t":"num"},{"t":"btwn","v":"coffee_machine_time_off","vt":"flow","v2":"heating_time_off","v2t":"flow"},{"t":"btwn","v":"heating_time_off","vt":"num","v2":"2359","v2t":"num"},{"t":"btwn","v":"0","vt":"num","v2":"morning_time_start","v2t":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":7,"x":691,"y":682.821533203125,"wires":[["db5574c3.2610e8"],["b86ea1e0.87cbd"],["358d8a41.2bb4e6"],["ce87d82d.5bd618"],["c5abb238.cda2f"],["31263b3f.343414"],["31263b3f.343414"]]},{"id":"db5574c3.2610e8","type":"change","z":"af7a5936.5847c8","name":"Set MORNING","rules":[{"t":"set","p":"payload","pt":"msg","to":"MORNING","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":944.5356063842773,"y":414.1072359085083,"wires":[[]]},{"id":"b86ea1e0.87cbd","type":"change","z":"af7a5936.5847c8","name":"Set DAY","rules":[{"t":"set","p":"payload","pt":"msg","to":"DAY","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":945.4641990661621,"y":482.5715026855469,"wires":[[]]},{"id":"2054ebda.874944","type":"debug","z":"af7a5936.5847c8","name":"ToD State Switch","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1594.6431579589844,"y":901.3216342926025,"wires":[]},{"id":"b8089dad.0bb29","type":"moment","z":"af7a5936.5847c8","name":"Date Time HHmm","topic":"","input":"payload","inputType":"msg","inTz":"Pacific/Auckland","adjAmount":0,"adjType":"days","adjDir":"add","format":"HHmm","locale":"POSIX","output":"payload","outputType":"msg","outTz":"Pacific/Auckland","x":214.00001525878906,"y":779.7858543395996,"wires":[["8bc65567.ab5ef8"]]},{"id":"ce87d82d.5bd618","type":"change","z":"af7a5936.5847c8","name":"Set EVENING","rules":[{"t":"set","p":"payload","pt":"msg","to":"EVENING","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1011.2856063842773,"y":614.5358867645264,"wires":[[]]},{"id":"c5abb238.cda2f","type":"change","z":"af7a5936.5847c8","name":"Set LATEEVENING","rules":[{"t":"set","p":"payload","pt":"msg","to":"LATEEVENING","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1023.4999847412109,"y":668.7143878936768,"wires":[[]]},{"id":"7b75fce1.37b0a4","type":"change","z":"af7a5936.5847c8","name":"Set NIGHT","rules":[{"t":"set","p":"payload","pt":"msg","to":"NIGHT","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1413.6177673339844,"y":998.4089002609253,"wires":[["ef560763.b33a48"]]},{"id":"efa23829.631e18","type":"switch","z":"af7a5936.5847c8","name":"Alarm Night Modifier","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"armed_night","vt":"str"},{"t":"neq","v":"armed_night","vt":"str"},{"t":"eq","v":"armed_away","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":1143.5813598632812,"y":1001.6203165054321,"wires":[["7b75fce1.37b0a4"],["20060081.ad9bc"],["7b75fce1.37b0a4"]]},{"id":"31263b3f.343414","type":"change","z":"af7a5936.5847c8","name":"Set NIGHT","rules":[{"t":"set","p":"payload","pt":"msg","to":"NIGHT","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":974.9284591674805,"y":720.5358409881592,"wires":[[]]},{"id":"8af47ef6.84452","type":"api-current-state","z":"af7a5936.5847c8","name":"Get Alarm State","server":"48eefced.ce1b34","outputs":1,"halt_if":"","halt_if_type":"num","halt_if_compare":"is","override_topic":true,"entity_id":"alarm_control_panel.alarm","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":941.7143783569336,"y":1010.1430826187134,"wires":[["efa23829.631e18"]]},{"id":"ef560763.b33a48","type":"api-call-service","z":"af7a5936.5847c8","name":"Update Time of Day","server":"48eefced.ce1b34","service_domain":"input_select","service":"select_option","data":"{\"entity_id\":\"input_select.time_of_day\",\"option\":\"{{payload}}\"}","mergecontext":"","output_location":"payload","output_location_type":"msg","x":1508.0001907348633,"y":838.2858972549438,"wires":[["2054ebda.874944"]]},{"id":"358d8a41.2bb4e6","type":"change","z":"af7a5936.5847c8","name":"Set LATEAFTERNOON","rules":[{"t":"set","p":"payload","pt":"msg","to":"LATEAFTERNOON","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1017.0193557739258,"y":549.4325122833252,"wires":[[]]},{"id":"c2efe21a.2a18e","type":"debug","z":"af7a5936.5847c8","name":"Current Time","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1277.01953125,"y":131.00390625,"wires":[]},{"id":"8bc65567.ab5ef8","type":"function","z":"af7a5936.5847c8","name":"Time Decision","func":"var morning_time_start = parseInt(flow.get(\"morning_time_start\"));\nvar morning_time_end = parseInt(flow.get(\"morning_time_end\"));\nvar sunset_minus_one = parseInt(flow.get(\"next_sunset\"));\nvar coffee_machine_time_off = parseInt(flow.get(\"coffee_machine_time_off\"));\nvar heating_time_off = parseInt(flow.get(\"heating_time_off\"));\nvar lamp_lighting_time_off = parseInt(flow.get(\"lamp_lighting_time_off\"));\nvar mignight = 0;\n\nvar lateafternoon = coffee_machine_time_off;\nvar evening = sunset_minus_one;\n//dayloing savings 1800 < 2000\nif (coffee_machine_time_off < sunset_minus_one)\n{\n evening = sunset_minus_one\n lateafternoon = coffee_machine_time_off\n} \nelse if (coffee_machine_time_off > sunset_minus_one)\n{\n evening = coffee_machine_time_off;\n}\n\n\nvar current_time = parseInt(msg.payload);\nnode.warn(\"Current_time: \" + current_time + \" coffee machine off: \" + coffee_machine_time_off + \" heating time off: \" + heating_time_off)\n\n//node.warn(\"coffee machine time off: \" + coffee_machine_time_off)\n//node.warn(\"sunset_minus_one: \" + sunset_minus_one)\n\nif (current_time > lamp_lighting_time_off)\n msg.payload = \"NIGHT\"\nelse if (current_time > heating_time_off)\n msg.payload = \"LATEEVENING\"\nelse if (current_time > evening)\n msg.payload = \"EVENING\";\nelse if (current_time > lateafternoon)\n msg.payload = \"LATEAFTERNOON\";\nelse if (current_time > morning_time_end)\n msg.payload = \"DAY\";\nelse if (current_time > morning_time_start)\n msg.payload = \"MORNING\";\nelse \n msg.payload = \"NIGHT\";\n\n\n/*if (current_time > coffee_machine_time_off & current_time < sunset_minus_one)\n msg.payload = \"EVENING\";\nelse if (current_time > sunset_minus_one & current_time < morning_time_end)\n msg.payload = \"LATEAFTERNOON\";\nelse if (current_time > morning_time_end & current_time <sunset_minus_one)\n msg.payload = \"DAY\";\nelse if (current_time > morning_time_start)\n msg.payload = \"MORNING\";\nelse \n msg.payload = \"NIGHT\";\n */ \nnode.warn(\" Final state: \" + msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":382.61266326904297,"y":883.0988788604736,"wires":[["b7da3db0.6a259","f2dacf64.779d9","800cab20.6e24e8"]]},{"id":"b7da3db0.6a259","type":"debug","z":"af7a5936.5847c8","name":"Current Time","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":309.019495010376,"y":532.0039978027344,"wires":[]},{"id":"f2dacf64.779d9","type":"switch","z":"af7a5936.5847c8","name":"Time of Day Switch","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"NIGHT","vt":"str"},{"t":"eq","v":"MORNING","vt":"str"},{"t":"eq","v":"DAY","vt":"str"},{"t":"eq","v":"LATEAFTERNOON","vt":"str"},{"t":"eq","v":"EVENING","vt":"str"},{"t":"eq","v":"LATEEVENING","vt":"str"}],"checkall":"true","repair":false,"outputs":6,"x":680.8571548461914,"y":878.5714807510376,"wires":[["8af47ef6.84452"],["ef560763.b33a48"],["ef560763.b33a48"],["ef560763.b33a48"],["ef560763.b33a48"],["8af47ef6.84452"]]},{"id":"20060081.ad9bc","type":"change","z":"af7a5936.5847c8","name":"Set LATEEVENING","rules":[{"t":"set","p":"payload","pt":"msg","to":"LATEEVENING","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1330.857078552246,"y":927.1428937911987,"wires":[["ef560763.b33a48"]]},{"id":"48eefced.ce1b34","type":"server","z":"","name":"Home Assistant","legacy":false,"hassio":false,"rejectUnauthorizedCerts":false,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true}]
Give that a go. I just started trying to re-add the time decision switch node, that function annoys me…my whole reason for want to move to node red is to reduce lines of code…
