I’ve made a simple automation to turn on lights when I come back home, it’s only triggered if it’s 30 minutes before sunset and if the lights are turned off, it works well before midnight, if I come back later the lights wont’ turn on. I’m sure that system is working because I set up a “welcome back” notification to my phone and that works every time, do you have any idea why this happens? Is it because of the sunset condition?
Thank you all, here is the script:
- alias: back home
platform: state
entity_id: device_tracker.me_phone_bt
to: home
condition:
condition: and
conditions:
- condition: sun
after: sunset
after_offset: "-00:30:00"
- condition: state
entity_id: light.entrance
state: "off"
- service: light.turn_on
color_name: green
- delay: 00:03:00
- service: light.turn_off
transition: "30"
Yes, it looks like it’s the sunset condition. Since you’ve only specified one time condition, it’ll only work from that condition until midnight.
Put in a sunrise condition as well, and that should fix it up.
@icaman004 is right. And since this can be a bit tricky:
- alias: back home
platform: state
to: home
condition:
- condition: state
state: "off"
- condition: or
conditions:
- condition: sun
after: sunset
- condition: sun
before: sunrise
before_offset: "00:30:00"
color_name: green
- delay: 00:03:00
transition: "30"
If you list multiple conditions under condition:
you don’t have to specify and
- that’s the default. So the above condition will be true if the light is off and it’s either between 30 minutes before sunset and midnight or between midnight and 30 minutes after sunrise. Adjust the offsets if you’d like a different time period.
Thank you all!
@pnbruckner I didn’t know that the default condition is an and, glad to know and thanks for the automation.
