Melotron
(Magnus Svensson)
November 16, 2022, 6:34pm
1
Greetings.
Iam trying to get my automation on living room lights going on lux.
I have a few virtual switches that I want to block the scripts from running and only when at least one are home.
But I am getting an error that doesn’t make sense to me.
“Message malformed: must contain at least one of below, above.”
Some how so doesn’t it want me to have a limit on 0 - 850 on the lux for the script. Why??
description: ""
mode: single
- type: illuminance
platform: device
device_id: a7ed6154826ffc40a51f06b10a6bd402
entity_id: sensor.hue_outdoor_sensor_illuminance
domain: sensor
- platform: numeric_state
for:
hours: 0
minutes: 5
seconds: 0
attribute: light_level
below: 850
above: 0
condition:
- condition: and
conditions:
- condition: state
entity_id: input_boolean.virt_sleep
state: "off"
- condition: state
entity_id: input_boolean.virt_manuell
state: "off"
- condition: state
entity_id: zone.home
attribute: persons
state: ">1"
- type: turn_on
device_id: 2b4bac3741e75a28dcdb424d3c5b1a20
entity_id: light.golv
domain: light
brightness_pct: 100
- type: turn_on
device_id: 7b1e3969a3d145da637e764681d8b43c
entity_id: light.hue_color_lamp_1
domain: light
brightness_pct: 100
- type: turn_on
device_id: 5f5e0fe8dd66cf3908547a6d892d3096
entity_id: light.hue_color_lamp_2
domain: light
brightness_pct: 100
- type: turn_on
device_id: a2af6fc664552d47532dc5ce8b75fdeb
entity_id: light.storarum_gardin
domain: light
brightness_pct: 100
- type: turn_on
device_id: 16b539f9da97dee8abac6f7fdeeefa1f
entity_id: light.storarum_led
domain: light
brightness_pct: 100
alias: Storarum 0-850 Lux
Thanks in advance.
123
(Taras)
November 16, 2022, 7:01pm
2
description: ""
mode: single
for:
minutes: 5
below: 850
condition:
- condition: state
state: "off"
- condition: state
state: "off"
- condition: numeric_state
attribute: persons
above: 1
- service: light turn_on
entity_id:
- light.golv
- light.hue_color_lamp_1
- light.hue_color_lamp_2
- light.storarum_gardin
- light.storarum_led
brightness_pct: 100
Melotron
(Magnus Svensson)
November 17, 2022, 3:31pm
3
Thanks alot!!
Iam going to test it asap
Iam currently doing my best to migrate from domoticz to home assistant for the second time.
The yalm are not sticking that good as lua in my head. But I guess that I need to work a lot more in that.
Regards Magnus
123
(Taras)
November 17, 2022, 3:44pm
4
Home Assistant uses YAML like a hierarchical form. The hierarchy is defined by indentation.
Melotron
(Magnus Svensson)
November 17, 2022, 4:32pm
5
I understand the basics of it, but it feels easyer with a script where you define local attribute and then a few “if” and "then"´s.
I find it easyer to have everything in scripts thats room and action defined as Envirement_livingroom.lua / tv_livingroom.lua to start the scene to watch tv.
My next problem are that Iam making an automation, but after that nothing happen lol
This are in the automations.yalm
- id: '1668701239641'
alias: Golv av
description: ''
- device_id: 1614cc3d16e12c9cdaf1f0390811e5f7
domain: deconz
platform: device
type: remote_button_short_press
subtype: turn_off
condition: []
- type: turn_off
domain: light
mode: single
After i press the off button the lamp stays on. Ive reloaded the automations in configuration.
I also try to make an automation and include it in the configuration.yalm
automation: !include Sovrum_switch.yalm
And again nothing happens when i press the switch.
Ive tryed to have it to a boolean switch and its the same there.
I am trying to get the switch to toggle a virtual switch that will halt my environment scripts in the rooms for when we go to sleep.
Do I need to create a script that calls on automations or how do I triger them???
Regards Magnus
123
(Taras)
November 17, 2022, 4:35pm
6
It’s yaml
not yalm
Melotron
(Magnus Svensson)
November 17, 2022, 4:47pm
7
Thanks, changed that but still the same problem.
123
(Taras)
November 17, 2022, 5:00pm
8
Check the automation’s trace.
Reference: Troubleshooting Automations
