I’m trying to automate my hallway lights and what seems like a straight forward thing to do turns increasingly complex the more I think about it. I was wondering if some of you have some ideas/input to point me in the right direction:
I have several triggers to turn the lights on and off:
Aeotec wallmote smart switch
Motion sensor
Pressure pad under the stairs
Currently the Aeotec wallmote smart switch simply turns the light on and off. However what I would like to achieve is the following:
The light comes on automatically when either
The pressure pad gets triggered
The motion sensor gets triggered
and it stays on for 5 min. Any fresh motion trigger resets the 5 min timer.
I’m not sure how to deal with the timer, re-setting it with each new motion trigger and pack this in a HA automation - any ideas?
I do it with two automations. Could do one but it starts getting complicated as I use an input_boolean when the robot vacuum is running.
alias: Study Lights On via Motion
description: Control Study Lights with Shelly Motion Detection
- platform: state
entity_id: binary_sensor.shellymotionsensor_study
to: 'on'
- platform: state
entity_id: binary_sensor.touchpad
to: 'on'
condition:
- condition: device
type: is_off
device_id: xxxxxxxxxxxx
entity_id: light.study_cans_current_value
domain: light
- service: light.turn_on
brightness: 159
mode: single
alias: Study Lights Off via Motion
- platform: state
to: 'off'
for:
hours: 0
minutes: 5
seconds: 0
milliseconds: 0
- platform: state
to: 'off'
for:
hours: 0
minutes: 5
seconds: 0
milliseconds: 0
condition:
- condition: state
entity_id: input_boolean.vacuum
state: 'off'
- service: light.turn_off
mode: single
I added a second trigger below the motion sensor for the pressure pad. You can do this from the UI.
It would be easier to give advice if you post the (properly formatted yaml) current version of the automation(s) you have and then exactly what isn’t working for you.
