beireken
(bart.e)
December 23, 2019, 4:11pm
1
I have following binary sensor controlling a HA service to toggle a light:
- platform: gpio
name: "2e Kinderkamer"
device_class: light
pin:
number: GPIO13
inverted: True
mode: INPUT_PULLUP
filters:
- delayed_on: 50ms
- delayed_off: 50ms
on_press:
then:
- homeassistant.service:
service: light.toggle
entity_id: light.wout
Now i would like this light to turn on to a certain brightness when the time is between certain hours at night. But i’m clueless how i could implement this with esphome.
I can always do a HA automation but would prefer it in esphome!
tom_l
December 24, 2019, 12:15am
2
See the examples on this page:
beireken
(bart.e)
December 24, 2019, 10:17am
3
I read that doc., problem is i’m no good automations and lambda’s.
Anyway i came up with this peiced together from other community threads:
- platform: gpio
device_class: light
pin:
number: GPIO13
inverted: True
mode: INPUT_PULLUP
filters:
- delayed_on: 50ms
- delayed_off: 50ms
on_press:
then:
- if:
condition:
- lambda: 'return id(ha_time).now().hour > 21;'
then:
brightness: "30"
- if:
condition:
- lambda: 'return id(ha_time).now().hour < 12;'
then:
brightness: "30"
on_double_click:
min_length: 50ms
max_length: 350ms
then:
service: light.turn_on
The time based brightness seems to work , just need to test a bit still if the double click to 100% brightness works as intended.
beireken
(bart.e)
December 24, 2019, 11:13am
4
and edited to the following to include else statement:
on_press:
then:
if:
condition:
or:
- lambda: 'return id(ha_time).now().hour < 7;'
then:
brightness: "30"
else:
on_double_click:
min_length: 50ms
max_length: 350ms
then:
