I have a fairly basic setup to change the color of one of my house lights to green/yellow/orange/red depending on a coarse voltage trigger. So the battery sensor gives me +20A, light is green, +15 yellow, -10 red.
The gauge card on lovelace has a define severity feature, which essentially does the same style of thing.
Would there be a way to link the colour of the light with the voltage in a bit more fluid way?
Use the hs_color attribute.
Set the saturation at 100% and vary the hue (0-120° for a red-yellow-green range) depending on your current.
A linear equation based on your red and green values gives:
hue == 4*Amps + 40
This puts yellow at 5A though.
That is definatly going the direction I was thinking…
Can I set this via a template ??
Once I get the workings of how to layout the yaml or whatever I can figure the maths
Well using my math above:
- service: light.turn_on
entity: light.your_light
hs_color:
- "{{ 4 * states('sensor.your_current_sensor')|float + 40 }}"
- 100
Thanks very much
We should limit the hue to allowed values, just in case:
- "{{ ([0, (4 * states('sensor.your_current_sensor')|float + 40), 360]|sort)[1] }}"
Just in case anyone else is interested, I added in the sensor for the charge state and the result is:
"{{ ([0, (4 * states('sensor.victron_battery_current')|float + 40)-
-8 * (states('sensor.victron_battery_state_of_charge')|float -100), 120]|sort)[1] }}"
Gives a nice smooth transition from red to green with some priority to charge state over current.
Thank you tom.
