Light control with multiple motion sensors
Hi.
I use this to turn a light on when motion is sensed, and off when no motion for 2 minutes.
I am using a Home-Assistent group with multiple sensors inside to accomplish this, but if I want to include multiple sensors without a Home-Assistant group, how can I do it?
[{"id":"1a8606fe98932706","type":"server-state-changed","z":"cbdda1d3e0543731","name":"group.bevegelse_gang_garderobe ON","server":"ce440416.77f1e8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"group.bevegelse_gang_garderobe","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":310,"y":1080,"wires":[["6a624760307800dd"],[]]},{"id":"35bf62b11b74ef46","type":"server-state-changed","z":"cbdda1d3e0543731","name":"group.bevegelse_gang_garderobe OFF (for 2Min)","server":"ce440416.77f1e8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"group.bevegelse_gang_garderobe","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"off","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"2","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":340,"y":1140,"wires":[["bdc2a934cbe0b3b7"],[]]},{"id":"bdc2a934cbe0b3b7","type":"api-call-service","z":"cbdda1d3e0543731","name":"light.zigbee_3 OFF","server":"ce440416.77f1e8","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.zigbee_3"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":650,"y":1140,"wires":[[]]},{"id":"6a624760307800dd","type":"api-call-service","z":"cbdda1d3e0543731","name":"light.zigbee_3 ON","server":"ce440416.77f1e8","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.zigbee_3"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":650,"y":1080,"wires":[[]]},{"id":"ce440416.77f1e8","type":"server","name":"Home Assistant","version":1,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
The drop down next to entity should give you the option list
So they will be work just like a Home-Assistant group if I add multiple sensors here?`
