Light control with smart switches and bulbs
I’m trying to set up my dashboard with the minimalist component. I have a custom:button card with the entity set as a Lutron Caseta diva dimmer. It controls 8 WiZ smart bulbs. So if I click it, it turns on the Lutron dimmer and all the lights come on. If I long press it, it gives me the option to set the dimmer level. I like that functionality but I’m unable to control the color as the card is controlling the dimmer rather than the bulbs. Is there a good way to be able to control the Lutron dimmer and the WiZ color from one card? Thanks
One thought is, instead of the long press calling up the dimmer level, use a subview that will display both the dimmer and the bulb, allowing you to set the one you want.
More information on subview can be found here:
Views - Home Assistant (home-assistant.io)
Great idea! I’m going to look into that. Thanks!
