I’d like to show and change the status of a light connected to esphome via a serial bus.
In Esphome, I set up the light and an output as follows:
light:
- platform: monochromatic
output: accent_light_output
output:
type: float
write_action:
# called when user changes light state from Home Assistant
- lambda: "transmitter->set_level(26, state);"
The code works fine for controlling the light from homeassistant with thetransmitter->setlevel
command.
When the status of the light changes (e.g. via a local switch), the script below is called. How do I set the new brightness in esphome so that is will be reflected in Homeassistant?
script:
- id: dimmer
parameters:
value: float
then:
# set the new brightness of the light in homeassistant
I tried calling turn_on
on the light, but this will call the write_action
and result in an infinite loop.
I must be missing something trivial …
