I have a zigbee Gledopto RGB+CCT led controller using zigbee2mqtt. It supports RGB + cold white, warm white, but I am using it with a strip that only supports RGB.
Is it possible in Home Assistant to only expose the RGB controls, pretend this is an RGB light, and hide color temperature?
I’d also like to know, as I have a WZ5 zigbee LED controller, also via zigbee2mqtt, which supports RGB, colour temperature etc. but I am just using it with a single colour strip, so I’d like to disable/hide all colour controls, I’m curious if this is possible.
