Light count is delayed - Help me clean up a bit - Template sensors
Hello all,
Currently I have a running Home assistant setup. However I’m having trouble with the way the lights turned on number is being calculated. It looks like it has a large delay in counting the lights on or off / not all light entitites state changes are registered instantly. I have a lights-groups.yaml file where I put certain lights in certain groups. I use light.all_lights_group in the code instead of just searching for all light entities since I do not wish all lights to be counted. In that group are only the lights I wish to be part of the count.
This is currently my template.yaml file.
#### Custom template sensors ##########################################################
#### Sprinkler Total Expected Precipitation trigger ###################################
- trigger:
    - platform: time_pattern
      minutes: /1
    - service: weather.get_forecasts
        type: hourly
        entity_id: weather.openweathermap
      response_variable: my_forecast
    - name: Sprinkler Total Expected Precipitation
      unique_id: eed1164d-2f8a-4197-88cf-80846bcbac63
      icon: mdi:weather-pouring
      unit_of_measurement: mm
      state: >
        {% set ns = namespace(totalprecipitation=0) %}
        {% if my_forecast and 'forecast' in my_forecast['weather.openweathermap'] %}
          {% for daypart in range(0, 7) %}
            {% set forecast = my_forecast['weather.openweathermap']['forecast'] %}
            {% if daypart < forecast | length %}
              {% set precipitation = forecast[daypart].precipitation %}
              {% set precipitation_probability = forecast[daypart].precipitation_probability / 100 %}
              {% if precipitation_probability > 0 %}
                {% set precipitation = precipitation * precipitation_probability %}
              {% endif %}
              {% set ns.totalprecipitation = ns.totalprecipitation + precipitation %}
            {% endif %}
          {% endfor %}
        {% endif %}
        {{ ns.totalprecipitation | float(0) | round(2) }}
#### Custom daily forecast sensor ###################################
- trigger:
      hours: /1
    - platform: homeassistant
      event: start
        type: daily
      response_variable: daily_forecast
    - name: daily_forecast_info
      state: "{{ states('weather.openweathermap') }}"
      attributes:
        forecast: "{{ daily_forecast['weather.openweathermap'].forecast }}"
    #### Sprinkler Total Rain Fallen Plus Expected ###################################
    - name: Sprinkler Total Rain Fallen Plus Expected
      unique_id: 2524c618-14f4-4db6-876f-8111b3c19bdf
      state: >
        {% set total_rain_fallen = states('input_number.sprinkler_total_rain_fallen') | float(0) %}
        {% set total_expected_precipitation = states('sensor.sprinkler_total_expected_precipitation') | float(0) %}
        {{ (total_rain_fallen + total_expected_precipitation) | round(2) }}
    #### Sprinkler Days Since Last Watering Day ####################################
    - name: Sprinkler Days Since Last Watering Day
      unique_id: f5af5762-f4d6-418e-801d-a24be0109d59
      icon: mdi:calendar
      state: >
        {{ ((as_timestamp(now()) - as_timestamp(states("input_datetime.sprinkler_last_Watering_day"))) / 86400) | float | round(2) }}
    #### Sprinkler Current Temperature Is Higher ###################################
    - name: Sprinkler Current Temperature Is Higher
      unique_id: 92d2df9d-dbe7-4bb9-94ce-9a368ac39be4
      icon: mdi:check
      state: >
        {%- if states('sensor.openweathermap_temperature') | float > states('input_number.sprinkler_maximum_temperature_measured') | float -%}
          true
        {%- else -%}
          false
        {%- endif %}
    #### Count how many lights are on ###################################
    - name: "Lights On Count"
      state: >
        {{ expand('light.all_lights_group') | selectattr('state', 'eq', 'on') | list | count }}
    #### Count how many doors and windows are open ###################################
    - name: "Open Doors and Windows Count"
      state: >
        {{ expand('binary_sensor.all_doors_and_windows') | selectattr('state', 'eq', 'on') | list | count }}
    #### Count how many devices have low battery ###################################
    - name: "Low Battery Devices Count"
      state: >
        {% set threshold = states('input_number.battery_threshold') | int %}
        {% set battery_sensors = namespace(count=0) %}
        {%- for state in states.binary_sensor
        | selectattr('attributes.device_class', 'defined')
        | selectattr('attributes.device_class', '==', 'battery')
        | selectattr('state', '==', 'on') -%}
            {% set battery_sensors.count = battery_sensors.count + 1 %}
        {%- endfor -%}
        {%- for state in states.sensor
        | selectattr('attributes.state_class', 'defined')
        | selectattr('attributes.state_class', '==', 'measurement')
        | selectattr('state', 'is_number') -%}
        {%- if state.state | int <= threshold -%}
        {%- endif -%}
        {%- endfor -%}
        {{ battery_sensors.count }}
    #### Check if trashcollection is today, tomorrow, the day after or in x days ###################################
    - name: "Trash Tomorrow"
      unique_id: "sensor_trash_tomorrow"
      state: >
        {% set target_date = states('sensor.afvalwijzer_next_date') %}
        {% if target_date %}
          {% set today = now().date() %}
          {% set target_date_obj = strptime(target_date, '%Y-%m-%d').date() %}
          {% set diff_days = (target_date_obj - today).days %}
          {% if diff_days == 0 %}
            today
          {% elif diff_days == 1 %}
            tomorrow
          {% elif diff_days == 2 %}
            the day after tomorrow
          {% elif diff_days > 2 %}
            in {{ diff_days }} days
          {% else %}
            unknown
          {% endif %}
        {% else %}
          unknown
        {% endif %}
    #### Calculate the remaining time for the washing machine ###################################
    - name: "Wasmachine Remaining Time v2"
      unique_id: wasmachine_remaining_time_v2
      state: >-
        {% set rem_h = (as_timestamp(states.sensor.wasmachine_washer_completion_time.state) - as_timestamp(now())) | timestamp_custom('%-H', false) %}
        {% set rem_m = (as_timestamp(states.sensor.wasmachine_washer_completion_time.state) - as_timestamp(now())) | timestamp_custom('%-M', false) %}
        {% if int(rem_h) > 0.9 %} {{ rem_h }} hour(s) and {{ rem_m }} minute(s)  {% else %} {{ rem_m }} minute(s) {% endif %}
    #### Create custom greeting sensor ###################################
    - name: "Greeting Sensor"
      unique_id: random_greeting_sensor
      state: >
        {% set hour = now().hour %}
        {% if hour < 12 %}
          {% set greetings = ["Goedemorgen", "Hallo"] %}
          {{ greetings | random }}
        {% elif hour < 18 %}
          {% set greetings = ["Goedemiddag", "Hallo"] %}
        {% else %}
          {% set greetings = ["Goedenavond", "Fijne avond", "Hoi", "Een prettige avond gewenst"] %}
        {% endif %}
Am I correct to note that all sensors under the “Custom daily forecast sensor” are only triggered once every hour? Ofcourse thats not what I want. If anyone can take a look for me and help me out or clean up the code I really appreciate it.
I also noticed just now that the service: get.weather_forecasts is giving me “string does not match the pattern of “deprecated”” Is this changed again recently?
Kind regards,
Remco
Yes it looks like at the moment all of your sensors are nested under the time trigger.
Try changing it by just adding “- sensor:” before the name block. This is what I have for my template sensors and they update whenever the referenced states are updated.
- sensor:
      state: >
The docs here have a bit more info.
Thanks, thats it.
I couldn’t figure it out since everytime I got a duplicate error when I tried -sensor: -name: but the spacing wasn’t right.
Thanks!
