Hi
I try to automate my Blebox dimmer. As far as I can tell it uses the standard lights integration.
So far I tried (inspired by: Service Calls - Home Assistant) the following in my /config/automations.yaml file:
- id: '1630341148432'
alias: Sunset Andreas Bedroom
description: ''
- platform: time
at: '12:41'
condition: []
service: light.turn_on
entity_id:: light.dimmer_andreas_bedroom_dimmerbox_brightness
brightness_pct: 50
mode: single
I also looked at another automation generated by the gui:
- id: '1630183855496'
alias: Shut of lights "Werkstatt Ost"
description: ''
- platform: time
at: 01:00
condition: []
- type: turn_off
device_id: 2f45e97c37e701d458e0e5e900d98590
entity_id: switch.licht_werkstatt_ost
domain: switch
mode: single
And I tried:
description: ''
- platform: time
at: '12:53'
condition: []
- type: turn_on
entity_id: light.dimmer_andreas_bedroom_dimmerbox_brightness
domain: light
mode: single
Which did not work either (missing device id? Where would I find it?).
It should be possible to dim the light from 0-100% since the lovelace slider allows this as well. But I cant figure out how to specify this in the yaml file.
