How would I make a dropdown with all the Light Effects a light has?
Had exactly the same question. Wanted a dropdownlist directly on the dashboard. Made the following solution:
Added this to my configuration.yaml
input_select:
wled_effects:
icon: mdi:led-strip
options:
- Solid
Then added the following to my automations.yaml
- alias: add effects for wled custom input
- platform: homeassistant
event: start
- service: input_select.set_options
entity_id: input_select.wled_effects
options: >
{{ state_attr('light.wled', 'effect_list') }}
- service: input_select.select_option
option: >
{{ state_attr('light.wled', 'effect') }}
- alias: set effect after change for wled custom input
- platform: state
- service: light.turn_on
entity_id: light.wled
effect: "{{ states('input_select.wled_effects') }}"
Please comment if there is a better way. Maybe the best way is to add this option to the WLED integration in Core (core/select.py at dfcadd600c1fb44de44a09b45c6b7312aeadaccf · home-assistant/core · GitHub).
