Light effects not resolving in editor
My D1 Mini config works and LEDs turn on fine, but when I try to add any effects, the compiler says it cannot find any of them. This is totally stumping me. Anyone see anything wrong here?
I have tried using both syntax (using a list and string literals)
esphome:
  platform: ESP8266
  board: d1_mini
wifi:
  ssid: "*******"
  password: "*******"
  ap:
    ssid: "Droid Depot Vaccum Port"
    password: "*********"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
output:
- platform: gpio
  pin: D6
light:
- platform: monochromatic
  output: gpio_D6
  name: 'Vacuume display blue LED'
  effects:
    - pulse:
I wasnt posting the picture to show code. I was showing the picture to show the error in the editor. Thanks
No I did not define the effect. I was just following the documentation
“ESPHome also offers a bunch of light effects you can use for your lights.”
Is there documentation on how to get a library added if its not already part of compilation?
Post whole ESPHome code but link you indicate gives you all explanations how to define some light presets in ESPHome :wink:
Following the documentation you posted, the effect is without a capital P, so change your yaml to:
    effects:
      - pulse:
:slight_smile:
Yeah like I said I tried both. Same result.
effects:
  - pulse:
and
effects: "Pulse"
and
effects: Pulse
all return with the same error.
Yes tried what the documentation mentions. Thats why I am here asking. :slight_smile:
Posted all the code :slight_smile: thanks
Uninstalling ESPHOME from HA and reinstalling fixed this issue.
