Light fails - can't reconfigure (ZHA)
Hello everybody
I’ve got a light which, now for the second time has stopped working. It can’t be controlled in HA, it stays off and when I try to turn it on it just turns off again.
It’s a Phillips Hue bulb (LWB010)
It works fine again, if I delete it from ZHA and re-add it, but I don’t want to keep doing that.
When I reconfigure it, I get this error:
I’ve added the diagnostics log in a comment below.
Do any of you guys know a fix for this?
Thanks!
Diagnostics log:
  "home_assistant": {
    "installation_type": "Home Assistant OS",
    "version": "2023.2.5",
    "dev": false,
    "hassio": true,
    "virtualenv": false,
    "python_version": "3.10.7",
    "docker": true,
    "arch": "aarch64",
    "timezone": "Europe/Copenhagen",
    "os_name": "Linux",
    "os_version": "5.15.84-v8",
    "supervisor": "2023.01.1",
    "host_os": "Home Assistant OS 9.5",
    "docker_version": "20.10.22",
    "chassis": "embedded",
    "run_as_root": true
  "custom_components": {
    "fuelprices_dk": {
      "version": "1.6",
      "requirements": [
        "beautifulsoup4",
        "html.parser"
    "hacs": {
      "version": "1.30.1",
      "requirements": [
        "aiogithubapi>=22.10.1"
    "xiaomi_cloud_map_extractor": {
      "version": "v2.2.0",
      "requirements": [
        "pillow",
        "pybase64",
        "python-miio",
        "requests",
        "pycryptodome"
    "eloverblik": {
      "version": "0.2.0",
      "requirements": [
        "pyeloverblik==0.3.1"
    "nordpool": {
      "version": "0.0.11",
      "requirements": [
        "nordpool>=0.2"
    "mass": {
      "version": "2023.2.1",
      "requirements": [
        "music-assistant==1.8.7.4"
    "roborock": {
      "version": "0.1.1",
      "requirements": [
        "python-roborock==0.1.5"
  "integration_manifest": {
    "domain": "zha",
    "name": "Zigbee Home Automation",
    "config_flow": true,
    "documentation": "https://www.home-assistant.io/integrations/zha",
    "requirements": [
      "bellows==0.34.7",
      "pyserial==3.5",
      "pyserial-asyncio==0.6",
      "zha-quirks==0.0.92",
      "zigpy-deconz==0.19.2",
      "zigpy==0.53.0",
      "zigpy-xbee==0.16.2",
      "zigpy-zigate==0.10.3",
      "zigpy-znp==0.9.2"
    "usb": [
        "vid": "10C4",
        "pid": "EA60",
        "description": "*2652*",
        "known_devices": [
          "slae.sh cc2652rb stick"
        "vid": "1A86",
        "pid": "55D4",
        "description": "*sonoff*plus*",
        "known_devices": [
          "sonoff zigbee dongle plus v2"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "sonoff zigbee dongle plus"
        "vid": "10C4",
        "pid": "EA60",
        "description": "*tubeszb*",
        "known_devices": [
          "TubesZB Coordinator"
        "vid": "1A86",
        "pid": "7523",
        "known_devices": [
        "vid": "1A86",
        "pid": "7523",
        "description": "*zigstar*",
        "known_devices": [
          "ZigStar Coordinators"
        "vid": "1CF1",
        "pid": "0030",
        "description": "*conbee*",
        "known_devices": [
          "Conbee II"
        "vid": "10C4",
        "pid": "8A2A",
        "description": "*zigbee*",
        "known_devices": [
          "Nortek HUSBZB-1"
        "vid": "0403",
        "pid": "6015",
        "description": "*zigate*",
        "known_devices": [
          "ZiGate+"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "ZiGate"
        "vid": "10C4",
        "pid": "8B34",
        "description": "*bv 2010/10*",
        "known_devices": [
          "Bitron Video AV2010/10"
    "codeowners": [
      "@dmulcahey",
      "@adminiuga",
      "@puddly"
    "zeroconf": [
        "type": "_esphomelib._tcp.local.",
        "name": "tube*"
        "type": "_zigate-zigbee-gateway._tcp.local.",
        "name": "*zigate*"
        "type": "_zigstar_gw._tcp.local.",
        "name": "*zigstar*"
        "type": "_slzb-06._tcp.local.",
        "name": "slzb-06*"
    "dependencies": [
      "file_upload"
    "after_dependencies": [
      "onboarding",
      "usb",
      "zeroconf"
    "iot_class": "local_polling",
    "loggers": [
      "aiosqlite",
      "bellows",
      "crccheck",
      "pure_pcapy3",
      "zhaquirks",
      "zigpy",
      "zigpy_deconz",
      "zigpy_xbee",
      "zigpy_zigate",
      "zigpy_znp"
    "is_built_in": true
  "data": {
    "ieee": "**REDACTED**",
    "nwk": 25023,
    "manufacturer": "Philips",
    "model": "LWB010",
    "name": "Philips LWB010",
    "quirk_applied": false,
    "quirk_class": "zigpy.device.Device",
    "manufacturer_code": 4107,
    "power_source": "Mains",
    "lqi": 255,
    "rssi": -48,
    "last_seen": "2023-02-21T18:23:50",
    "available": true,
    "device_type": "Router",
    "signature": {
      "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4107, maximum_buffer_size=71, maximum_incoming_transfer_size=45, server_mask=0, maximum_outgoing_transfer_size=45, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
      "endpoints": {
        "11": {
          "profile_id": 49246,
          "device_type": "0x0100",
          "in_clusters": [
            "0x0000",
            "0x0003",
            "0x0004",
            "0x0005",
            "0x0006",
            "0x0008",
            "0x1000"
          "out_clusters": [
            "0x0019"
        "242": {
          "profile_id": 41440,
          "device_type": "0x0061",
          "in_clusters": [
            "0x0021"
          "out_clusters": [
            "0x0021"
    "active_coordinator": false,
    "entities": [
        "entity_id": "button.bedroom_identify",
        "entity_id": "light.bedroom",
        "entity_id": "number.bedroom_start_up_current_level",
        "entity_id": "select.bedroom_start_up_behavior",
    "neighbors": [
        "rx_on_when_idle": "On",
        "relationship": "Parent",
        "extended_pan_id": "**REDACTED**",
        "nwk": "0xA0CC",
        "permit_joining": "Accepting",
        "depth": "1",
        "lqi": "219"
        "relationship": "NoneOfTheAbove",
        "nwk": "0x421B",
        "depth": "2",
        "lqi": "252"
        "device_type": "Coordinator",
        "nwk": "0x0000",
        "depth": "0",
        "lqi": "255"
        "nwk": "0xFE47",
        "depth": "2",
        "lqi": "192"
        "nwk": "0x3F39",
        "depth": "2",
        "lqi": "201"
        "nwk": "0x13D0",
        "depth": "2",
        "lqi": "252"
        "nwk": "0xDB40",
        "depth": "2",
        "lqi": "163"
        "nwk": "0xB870",
        "depth": "2",
        "lqi": "146"
        "nwk": "0x9244",
        "depth": "2",
        "lqi": "167"
        "nwk": "0xA577",
        "depth": "2",
        "lqi": "252"
        "nwk": "0x5FB2",
        "depth": "2",
        "lqi": "164"
        "nwk": "0x41CB",
        "depth": "2",
        "lqi": "169"
    "routes": [
        "dest_nwk": "0x0000",
        "route_status": "Active",
        "memory_constrained": false,
        "many_to_one": true,
        "route_record_required": false,
        "next_hop": "0x0000"
    "endpoint_names": [
        "name": "DIMMABLE_LIGHT"
        "name": "unknown 97 device_type of 0xa1e0 profile id"
    "user_given_name": "Bedroom",
    "device_reg_id": "8b065f67096b11ebab3141643c8a446f",
    "area_id": null,
    "cluster_details": {
      "11": {
        "device_type": {
          "name": "DIMMABLE_LIGHT",
          "id": 256
        "in_clusters": {
          "0x0000": {
            "endpoint_attribute": "basic",
            "attributes": {
              "0x0004": {
                "attribute_name": "manufacturer",
                "value": "Philips"
              "0x0005": {
                "attribute_name": "model",
                "value": "LWB010"
            "unsupported_attributes": {}
          "0x0003": {
            "endpoint_attribute": "identify",
            "attributes": {},
          "0x0004": {
            "endpoint_attribute": "groups",
            "attributes": {},
          "0x0005": {
            "endpoint_attribute": "scenes",
            "attributes": {},
          "0x0006": {
            "endpoint_attribute": "on_off",
            "attributes": {
              "0x0000": {
                "attribute_name": "on_off",
                "value": 0
              "0x4003": {
                "attribute_name": "start_up_on_off",
                "value": 1
          "0x0008": {
            "endpoint_attribute": "level",
            "attributes": {
              "0x0000": {
                "attribute_name": "current_level",
                "value": 254
              "0x4000": {
                "attribute_name": "start_up_current_level",
                "value": 254
              "0x0012": {
                "attribute_name": "on_transition_time"
              "0x0014": {
                "attribute_name": "default_move_rate"
              "0x0010": {
                "attribute_name": "on_off_transition_time"
              "0x0011": {
                "attribute_name": "on_level"
              "0x0013": {
                "attribute_name": "off_transition_time"
          "0x1000": {
            "endpoint_attribute": "lightlink",
            "attributes": {},
        "out_clusters": {
          "0x0019": {
            "endpoint_attribute": "ota",
            "attributes": {},
      "242": {
        "device_type": {
          "name": "unknown",
          "id": 97
        "in_clusters": {
          "0x0021": {
            "endpoint_attribute": "green_power",
            "attributes": {},
        "out_clusters": {
          "0x0021": {
            "attributes": {},
