So I have an issue that popped up a few updates ago. I have a light group of 3 RGBW bulbs. These bulbs are flashed with Tasmota. The bulbs will respond perfectly to color changes via the UI, however when I click on “White” nothing happens. Anyone else have this issue or fix? I am on 2021.7.3. and Tasmota 9.5.0 Screen Shot
If I manually switch all the lights in the group to white via Tasmota. HA will recognize this change and reflect so via the UI. However adjusting the white slider on the HA UI is only sending the “ON” command without any dimmer information. Screen Shot
