Can we do that?
some thing like:
light:
- platform: group
area:
- dining_room
- kitchen
and so on…
the idea is to update the area or add a new light to the area and update the group automatically…
Can we do that?
some thing like:
light:
- platform: group
area:
- dining_room
- kitchen
and so on…
Should be possible to do it with templates. Create an automation that creates that group on start up based on the rooms. You could also create a blueprint in order to easily manage the rooms / create multiple groups.
All on that is where I need some help… may be a lot of help.
I can create something for you in a bit. If you just want to be able to turn on/off lights you can use something like this
service: light.toggle
data: {}
area_id:
- room1
- room2
Nevertheless I created an automation for you:
Was there no way to fulfill the following requirement?
You can add new lights to an area by adding them to the area. If you then also want to add them to the group, you need to manually rerun the automation. In all honesty, I don’t think that anyone is constantly adding/removing lights anyway. I also don’t know how to create a trigger that reacts to a new entity or its change of area id.
The following (demo) automation triggers when an entity’s information is updated. It uses an Event Trigger listening for entity_registry_updated
. Obviously several kinds of updates are possible so the condition limits it to the one that contains the area_id
property.
alias: Entity Area Updated
description: ""
- platform: event
event_type: entity_registry_updated
event_data:
action: update
condition:
- "{{ trigger.event.data.changes.area_id is defined }}"
- service: notify.persistent_notification
message: >
{{ trigger.event.data.changes.area_id if
trigger.event.data.changes.area_id is not none else 'undefined' }}
mode: single
Ideally, area_id
would report the entity’s new assigned area. Curiously, it reports the entity’s old assigned area (or null if the entity had no previously assigned area).
Here’s an example of an entity_registry_updated
event.
action: update
entity_id: input_boolean.switch_1
changes:
area_id: f1a3e02eadba4e7c81fa5f56d0d39f8f
origin: LOCAL
time_fired: "2023-01-10T21:24:56.597424+00:00"
context:
parent_id: null
user_id: null
