I’ve set up some nested light groups and added those to my lovelace dashbaord using the light card.
Sometimes this works without any issue but out of the sudden those cards show “unavailable”. Reloading my groups by going to “Configuration->Server Controls->YAML configuration reloading->Groups, Group Entities…” immediately fixes the issue.
To everyone having the same problem: I found the solution.
Light groups are created sequentially. So if you use nested light groups (light groups in light groups), make sure to define the light groups you want to use in higher level light groups before you define those.
For example, if you want to have light groups like those:
Living Room Ceiling
Living Room Ambience
Living Room All
… then you have to make sure to define the “All” group after “Ceiling” and “Ambience” because it needs them to be defined in advance.
