Home Assistant is installed on VirtualBox.
Some of my zwave light switches show up as switches and my dimmers show up as lights. In my configuration.yaml I have the switches converted over to lights so I can then create light groups. The light groups have been working great for the last month. I was using core version 2021.2.3. I upgraded to 2021.3.1 and now the light groups do not work. It’s like HA is not recognizing the “light” section in my configuration.yaml. As an example, one of my switches is switch.kitchen. In the “light” section in my configuration.yaml I have it set to light.kitchen. I have a lovelace button card configured for the light.kitchen switch. If I press the button, nothing happens. The light does nothing but if I change the entity to switch.kitchen, it works. The light turns on/off.
homeassistant:
packages: !include_dir_named packages
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
frontend:
themes: !include_dir_merge_named themes
# DuckDNS
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
light:
### Convert switches to lights ###
- platform: switch
name: Living Room Front
entity_id: switch.living_room_front
- platform: switch
name: Living Room Back
entity_id: switch.living_room_back
- platform: switch
entity_id: switch.kitchen
- platform: switch
entity_id: switch.downstairs_hallway
- platform: switch
entity_id: switch.upstairs_hallway
### Groups ###
- platform: group
name: Living Room Lights
entities:
- light.living_room_front
- light.living_room_back
- platform: group
entities:
- light.kitchen
- light.downstairs_hallway
- light.upstairs_hallway
- platform: group
entities:
- light.kitchen
- light.jaspers_light
- light.logans_light
- light.master_bedroom_light
- platform: group
entities:
I also have this error message in my logs.
Logger: homeassistant.helpers.service
Source: helpers/service.py:115
First occurred: 11:04:20 AM (6 occurrences)
Last logged: 11:05:12 AM
Unable to find referenced entities light.downstairs_hallway
Unable to find referenced entities light.living_room_back
I loaded a previous snapshot and the light groups worked. I reinstalled 2021.3.1 and the light groups did work for a little while. Before I knew there was still an issue, I updated the Supervisor to 2021.03.4. When I found out the issue was still there, I loaded the snapshot again but then all of my integrations were disabled. I found out the Supervisor was still at the newest version 2021.03.4. I had to reinstall 2021.3.1 to fix the disabled integrations. So, I am stuck on the newest version of core and my light groups do not work.
Preferably, I would like to get the light groups to work but if not, downgrading the Supervisor is also an option. Any help is greatly appreciated.
