I copy paste the log, the part I turn off the lights. The part where says “sending zigbee request” to each bulbs but one. The one that did not do that in the log is the one that failed in HA. I can’t understand anything else from the log
2021-11-10 18:02:18 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=light, service=turn_off, service_data=entity_id=light.luces_comedor>
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Sending Zigbee multicast with tsn 44 under 45 request id, data: b'012c00'
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (17, 45, 0, <DeconzAddressEndpoint address_mode=ADDRESS_MODE.GROUP address=0x0005 endpoint=None>, 260, 6, 1, b'\x01,\x00', 2, 0)
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.uart] Send: 0x129200180011002d0001050004010600010300012c000200
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.uart] Frame received: 0x12920009000200222d
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.api] APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 45]
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.uart] Frame received: 0x0e93000700aa00
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.api] Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_INDICATION|2: 170>, 0]
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_indication (1, 1)
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.uart] Send: 0x1793000800010001
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.uart] Frame received: 0x17930021001a00220105000102000001040106000300012c0000af0a4ac8370005
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.api] APS data indication response: [26, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, <DeconzAddress address_mode=ADDRESS_MODE.GROUP address=0x0005>, 1, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, 1, 260, 6, b'\x01,\x00', 0, 175, 10, 74, 200, 55, 0, 5]
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy.device] Ignoring message (b'012c00') on cluster 6: unknown endpoint or cluster id: 'No cluster ID 0x0006 on (00:21:2e:ff:ff:07:1b:45, 1)'
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.api] 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, ep: 1, profile: 0x0104, cluster_id: 0x0006, data: b'012c00'
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.uart] Frame received: 0x0e94000700a600
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.api] Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 166>, 0]
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_confirm (0,)
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.uart] Send: 0x04940007000000
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.uart] Frame received: 0x04940012000b00222d010500010000000000
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.api] APS data confirm response for request with id 45: 00
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.api] Request id: 0x2d 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.GROUP address=0x0005 endpoint=None>, status: 0x00
2021-11-10 18:02:18 DEBUG (MainThread) [homeassistant.components.zha.entity] light.luces_comedor: turned off: [0, <Status.SUCCESS: 0>]
2021-11-10 18:02:18 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.luces_comedor, old_state=<state light.luces_comedor=on; min_mireds=250, max_mireds=454, supported_color_modes=['color_temp'], color_mode=color_temp, brightness=254, color_temp=391, hs_color=(28.728, 70.496), rgb_color=(255, 161, 75), xy_color=(0.541, 0.389), off_brightness=None, friendly_name=Luces_Comedor, supported_features=43 @ 2021-11-10T18:01:00.360228+01:00>, new_state=<state light.luces_comedor=off; min_mireds=250, max_mireds=454, supported_color_modes=['color_temp'], off_brightness=None, friendly_name=Luces_Comedor, supported_features=43 @ 2021-11-10T18:02:18.066735+01:00>>
2021-11-10 18:02:18 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [548502600960] Sending {"id": 2, "type": "event", "event": {"event_type": "state_changed", "data": {"entity_id": "light.luces_comedor", "old_state": {"entity_id": "light.luces_comedor", "state": "on", "attributes": {"min_mireds": 250, "max_mireds": 454, "supported_color_modes": ["color_temp"], "color_mode": "color_temp", "brightness": 254, "color_temp": 391, "hs_color": [28.728, 70.496], "rgb_color": [255, 161, 75], "xy_color": [0.541, 0.389], "off_brightness": null, "friendly_name": "Luces_Comedor", "supported_features": 43}, "last_changed": "2021-11-10T17:01:00.360228+00:00", "last_updated": "2021-11-10T17:01:00.360228+00:00", "context": {"id": "d08b89e2c8be1c3885613cfeb83475e0", "parent_id": null, "user_id": "718e43cedf694b0d812e1df562c01a2b"}}, "new_state": {"entity_id": "light.luces_comedor", "state": "off", "attributes": {"min_mireds": 250, "max_mireds": 454, "supported_color_modes": ["color_temp"], "off_brightness": null, "friendly_name": "Luces_Comedor", "supported_features": 43}, "last_changed": "2021-11-10T17:02:18.066735+00:00", "last_updated": "2021-11-10T17:02:18.066735+00:00", "context": {"id": "573372deb6e6e2e3972c33be1c75e251", "parent_id": null, "user_id": "718e43cedf694b0d812e1df562c01a2b"}}}, "origin": "LOCAL", "time_fired": "2021-11-10T17:02:18.066735+00:00", "context": {"id": "573372deb6e6e2e3972c33be1c75e251", "parent_id": null, "user_id": "718e43cedf694b0d812e1df562c01a2b"}}}
2021-11-10 18:02:18 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [548199012384] Sending {"id": 2, "type": "event", "event": {"event_type": "state_changed", "data": {"entity_id": "light.luces_comedor", "old_state": {"entity_id": "light.luces_comedor", "state": "on", "attributes": {"min_mireds": 250, "max_mireds": 454, "supported_color_modes": ["color_temp"], "color_mode": "color_temp", "brightness": 254, "color_temp": 391, "hs_color": [28.728, 70.496], "rgb_color": [255, 161, 75], "xy_color": [0.541, 0.389], "off_brightness": null, "friendly_name": "Luces_Comedor", "supported_features": 43}, "last_changed": "2021-11-10T17:01:00.360228+00:00", "last_updated": "2021-11-10T17:01:00.360228+00:00", "context": {"id": "d08b89e2c8be1c3885613cfeb83475e0", "parent_id": null, "user_id": "718e43cedf694b0d812e1df562c01a2b"}}, "new_state": {"entity_id": "light.luces_comedor", "state": "off", "attributes": {"min_mireds": 250, "max_mireds": 454, "supported_color_modes": ["color_temp"], "off_brightness": null, "friendly_name": "Luces_Comedor", "supported_features": 43}, "last_changed": "2021-11-10T17:02:18.066735+00:00", "last_updated": "2021-11-10T17:02:18.066735+00:00", "context": {"id": "573372deb6e6e2e3972c33be1c75e251", "parent_id": null, "user_id": "718e43cedf694b0d812e1df562c01a2b"}}}, "origin": "LOCAL", "time_fired": "2021-11-10T17:02:18.066735+00:00", "context": {"id": "573372deb6e6e2e3972c33be1c75e251", "parent_id": null, "user_id": "718e43cedf694b0d812e1df562c01a2b"}}}
2021-11-10 18:02:18 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [548111894128] Sending {"id": 26, "type": "event", "event": {"event_type": "state_changed", "data": {"entity_id": "light.luces_comedor", "old_state": {"entity_id": "light.luces_comedor", "state": "on", "attributes": {"min_mireds": 250, "max_mireds": 454, "supported_color_modes": ["color_temp"], "color_mode": "color_temp", "brightness": 254, "color_temp": 391, "hs_color": [28.728, 70.496], "rgb_color": [255, 161, 75], "xy_color": [0.541, 0.389], "off_brightness": null, "friendly_name": "Luces_Comedor", "supported_features": 43}, "last_changed": "2021-11-10T17:01:00.360228+00:00", "last_updated": "2021-11-10T17:01:00.360228+00:00", "context": {"id": "d08b89e2c8be1c3885613cfeb83475e0", "parent_id": null, "user_id": "718e43cedf694b0d812e1df562c01a2b"}}, "new_state": {"entity_id": "light.luces_comedor", "state": "off", "attributes": {"min_mireds": 250, "max_mireds": 454, "supported_color_modes": ["color_temp"], "off_brightness": null, "friendly_name": "Luces_Comedor", "supported_features": 43}, "last_changed": "2021-11-10T17:02:18.066735+00:00", "last_updated": "2021-11-10T17:02:18.066735+00:00", "context": {"id": "573372deb6e6e2e3972c33be1c75e251", "parent_id": null, "user_id": "718e43cedf694b0d812e1df562c01a2b"}}}, "origin": "LOCAL", "time_fired": "2021-11-10T17:02:18.066735+00:00", "context": {"id": "573372deb6e6e2e3972c33be1c75e251", "parent_id": null, "user_id": "718e43cedf694b0d812e1df562c01a2b"}}}
2021-11-10 18:02:18 DEBUG (MainThread) [homeassistant.components.zha.entity] light.comedor1: polling current state
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 46 under 47 request id, data: b'002e000000'
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (20, 47, 0, <DeconzAddressEndpoint address_mode=2 address=0x190F endpoint=1>, 260, 6, 1, b'\x00.\x00\x00\x00', 2, 0)
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.uart] Send: 0x1295001b0014002f00020f190104010600010500002e0000000200
2021-11-10 18:02:18 DEBUG (MainThread) [homeassistant.components.zha.entity] light.comedor7: polling current state
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 48 under 49 request id, data: b'0030000000'
2021-11-10 18:02:18 DEBUG (MainThread) [homeassistant.components.zha.entity] light.comedor2: polling current state
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 50 under 51 request id, data: b'0032000000'
2021-11-10 18:02:18 DEBUG (MainThread) [homeassistant.components.zha.entity] light.comedor4: polling current state
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 52 under 53 request id, data: b'0034000000'
2021-11-10 18:02:18 DEBUG (MainThread) [homeassistant.components.zha.entity] light.comedor3: polling current state
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 54 under 55 request id, data: b'0036000000'
2021-11-10 18:02:18 DEBUG (MainThread) [homeassistant.components.zha.entity] light.comedor5: polling current state
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 56 under 57 request id, data: b'0038000000'
2021-11-10 18:02:18 DEBUG (MainThread) [homeassistant.components.zha.entity] light.comedor6: polling current state
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 58 under 59 request id, data: b'003a000000'
2021-11-10 18:02:18 DEBUG (MainThread) [zigpy_deconz.uart] Frame received: 0x12950009000200222f
