Light in house with state feedback
Hi everyone,
i am asking community because i loose myself.
I wish to control light in my house ( the idea is to put a switch/relay behing all light, and control them with wireless wall switch )
Actually i tested this switch ( Tuya zigbee )
And this swtich/relay ( in wifi ) :
This is working BUT i don’t have the state feedback :frowning:
( the tuya application have the feedback, but no HA )
I am actually with Home assitant OS in a VM. If needeed i can switch on raspberry pi witch Conbee II key, but i need your advice before loosing money for nothing.
What do you use in your configuration ? ( how do you know switch state ? ) Thanks !
What has wifi to do with it?
sorry, i don’t understand the remark… it’s just that my relay ( witch cut or not the line ) is working with wifi and not with zigbee
My led controller or my yeelight bulb have a state return, ie if i switch this light without using HA, the state is correctly uploaded to HA, but not the relay. So i wondering witch relais can do this.
so anyone know relay switch witch state return in home assistant ?
So you have a zigbee relay according to the description in the picture you posted, not wifi.
the picture is not accurate, by the way i have 2 modules, one wifi and one on zigbee…
Any relay supported in HA should report state correctly. What is the relay? Make and model, not an inaccurate picture.
The Relay is “Girier” model JR-ZDS01
But i feel stupid, i can’t successfully add it in phoscon for now, only seen when i add it in tuya integration
( it’s a relay, not light , switch or sensor )
edit : uninstalled Deconz, and trying ZHA
Edit 2 : Success with ZHA \o/
