Switch the event state around. Then use the transition
key. This way it waits 30sec for the motion to be off and will take 10 sec to transition to off. If it retriggers calling "transition": 0
with the on command will override the previous transition to off.
[{"id":"86788b1044def783","type":"server-state-changed","z":"f80b6c338afd5483","name":"","server":"6b1110b5.183a4","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"motion sensor","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"off","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"30","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"date"}],"x":400,"y":4620,"wires":[["b75470d6eabf5cca"],["47b47840e8f32fdd"]]},{"id":"b75470d6eabf5cca","type":"api-call-service","z":"f80b6c338afd5483","name":"","server":"6b1110b5.183a4","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":[],"data":"{\"transition\":10}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":750,"y":4580,"wires":[[]]},{"id":"47b47840e8f32fdd","type":"api-call-service","z":"f80b6c338afd5483","name":"","server":"6b1110b5.183a4","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":[],"data":"{\"transition\":0}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":750,"y":4660,"wires":[[]]},{"id":"6b1110b5.183a4","type":"server","name":"Home Assistant","version":4,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m"}]
