Tonsen01
(Tonsen01)
December 5, 2024, 7:38am
1
I built a CO2 sensor with ESP Home that signals the air quality through different colors on an LED strip (green/yellow/red). Now I have the phenomenon that the LEDs are turned off every day at 5:00 AM (Status LED / NeoPixel Light) even though there is no configuration for this. However, I turn off my Wi-Fi at night, which is reactivated at 5:00 AM. But I can’t find any reason why the LEDs are turned off after the Wi-Fi is turned back on. The turning off of the LEDs is shown in the logbook.
Does anyone have any idea what could be causing this? I would greatly appreciate any feedback.
Troon
(Troon)
December 5, 2024, 8:13am
2
Likely a reboot from the wifi coming back up , but without the (correctly-formatted ) ESPHome config, we’re guessing.
Tonsen01
(Tonsen01)
December 5, 2024, 8:59am
3
I have no idea. This is my config:
esphome:
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: xxx
services:
- service: recalibrate_scdx_co2
variables:
actual_co2: int
then:
- scd30.force_recalibration_with_reference:
value: !lambda 'return actual_co2;'
external_components:
- source: github://bekriebel/esphome@scd30_force_calibration_with_reference
components: [ scd30 ]
# Example configuration entry
switch:
- platform: restart
ota:
platform: esphome
password: "db19f7bad7a0214cd0aa0846ed9211e0"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Co2-Sensor-2 Fallback Hotspot"
password: "mgH7mhfIK4G8"
# Example configuration entry for ESP32
i2c:
sda: GPIO4
scl: GPIO5
scan: true
- platform: scd30
co2:
on_value_range: # Schwellwerte für die Ampel
- below: 1000
then:
- light.turn_on:
brightness: 30%
red: 0%
green: 100%
blue: 0%
- above: 1000
below: 1400
then:
- light.turn_on:
brightness: 30%
red: 100%
green: 80%
blue: 0%
- above: 1400
then:
- light.turn_on:
brightness: 35%
red: 100%
green: 0%
blue: 10%
update_interval: 10s
temperature:
name: "co2-Sensor-2 Temperatur"
accuracy_decimals: 1
humidity:
name: "co2-Sensor-2 Luftfeuchtigkeit"
automatic_self_calibration: off
temperature_offset: 1.5 °C
address: 0x61
altitude_compensation: 105m
light:
- platform: neopixelbus
type: GRB
variant: WS2812X
pin: GPIO3
num_leds: 10
- platform: partition
name: "CO2 Status LED"
segments:
- id: co2_status_led
to: 9
captive_portal:
Troon
(Troon)
December 5, 2024, 9:05am
4
Try disabling the reboot and AP timeouts:
wifi:
reboot_timeout: 0s
ap:
ap_timeout: 0s
and remove the final captive_portal
line (docs ).
If that doesn’t work, try not turning your wifi off overnight and confirm that the device works as expected.
Tonsen01
(Tonsen01)
December 5, 2024, 9:52am
5
Thank you! I will try that a give feedback later.
Tonsen01
(Tonsen01)
December 6, 2024, 7:38am
6
Today the LED Stripe turns off again. This is the log of the sensor from today.
6. Dezember 2024
co2-sensor-2 was located at home
05:01:06 - 3 hours ago
co2-sensor-2 Restart
05:00:45 - 3 hours ago
CO2 Status LED shut off
NeoPixel Light shut off
Really strange. This is my new code:
esphome:
esp8266:
board: d1_mini
# Enable logging
logger:
api:
encryption:
key: "F4YoGDdBD3Pl/LaccgudlQl0q6IJQlOHgmFlGq08MrU="
services:
variables:
actual_co2: int
then:
switch:
- platform: restart
ota:
platform: esphome
wifi:
reboot_timeout: 0s
ap:
ap_timeout: 0s
i2c:
sda: GPIO4
scl: GPIO5
scan: true
- platform: scd30
co2:
- below: 1000
then:
- light.turn_on:
brightness: 25%
red: 0%
green: 100%
blue: 0%
- above: 1000
below: 1400
then:
- light.turn_on:
brightness: 25%
red: 100%
green: 80%
blue: 0%
- above: 1400
then:
- light.turn_on:
brightness: 30%
red: 100%
green: 0%
blue: 10%
temperature:
humidity:
address: 0x61
light:
type: GRB
variant: WS2812X
pin: GPIO3
num_leds: 10
segments:
to: 9
EBME2
(Ebme2)
December 6, 2024, 10:05am
7
Try adding reboot_timeout to your api section see the docs here
api:
encryption:
reboot_timeout: 0s
I think I’d actually set it to something like 12 hours, or longer than your Wi-Fi off period, I have never tried setting it that long though.
Tonsen01
(Tonsen01)
December 6, 2024, 6:17pm
8
Thanks for your reply. I will try it and give an update later.
Tonsen01
(Tonsen01)
December 9, 2024, 9:09am
9
Unfortunately the same situation. This ist my actual confifg. I have also disabled the wifi fall back.
esphome:
esp8266:
board: d1_mini
# Enable logging
logger:
api:
encryption:
services:
variables:
actual_co2: int
then:
switch:
- platform: restart
ota:
platform: esphome
wifi:
reboot_timeout: 9h
#ap:
#ssid: "Co2-Sensor-2 Fallback Hotspot"
#password: "mgH7mhfIK4G8"
#ap_timeout: 9h
i2c:
sda: GPIO4
scl: GPIO5
scan: true
- platform: scd30
co2:
- below: 1000
then:
- light.turn_on:
brightness: 25%
red: 0%
green: 100%
blue: 0%
- above: 1000
below: 1400
then:
- light.turn_on:
brightness: 25%
red: 100%
green: 80%
blue: 0%
- above: 1400
then:
- light.turn_on:
brightness: 30%
red: 100%
green: 0%
blue: 10%
temperature:
humidity:
address: 0x61
light:
type: GRB
variant: WS2812X
pin: GPIO3
num_leds: 10
segments:
to: 9
EBME2
(Ebme2)
December 9, 2024, 6:27pm
10
Your config above doesn’t have the reboot_timeout: 0s in the api section, my guess is you will need it in both.
Tonsen01
(Tonsen01)
December 10, 2024, 6:55am
11
Thank you for your notice. I have just added it and will now see what happens tomoorrow.
