looking at this integration: light.mqtt
i have a couple lights on my zwave network on zwave2mqtt, which then show up in HA as a mqtt device.
on the zwave side, i have one RGB controller which only gives me the RGBW setting to adjust the light
in a #RRGGBBWW format
so i have no “seperate” W channel, just the W that is part of this variable.
in HA, we define a light, type mqtt, and we can define an rgb_value_template, but the rgb control only has red, greed, and blue variables built in.
the mqtt.light does have a white channel option, but no way i can see to get that into the rgb_command_template.
IS there any way to add a white value to the rgb command, or some other way to make this work?
"rgb_command_template": "{{ \"#%02x%02x%02x\" | format(red, green, blue)}}",
"rgb_command_topic": "homeassistant/77/51/1/0/set",
"rgb_state_topic": "homeassistant/77/51/1/0",
"rgb_value_template": "{{ value_json.value[1:3] | int(0, 16) }},{{ value_json.value[3:5] | int(0, 16) }},{{ value_json.value[5:7] | int(0, 16) }}",
