After an evening of real world use i think you are right. It was not really noticeable apart from in the kitchen where even though we were in it the light was still going off way quicker than it should.
So i have changed the flow for the kitchen to include what you said a few posts back
$entities('input_boolean.good_night_good_bye').state = 'on' ? 20 : 300
I have included the flow for the Kitchen below just so we know where i am right now. I know we was looking at dining room but to be fair i am using the same logic for all the rooms that need it. I will give it some real world testing today / this evening and see if its any better.
[{"id":"4702f2af3c981df9","type":"group","z":"f4d699e3f5593b7b","name":"Turn Kitchen Lights - On - Off - If Alseep or away from home only turn on for 20 seconds","style":{"label":true},"nodes":["b813d119661b7826","d7ae93874e9e42d5","836a9ec058e0f16f","3a22270b2b637ea5","58300163b07271ca","df5f749a45e913a9","3981fbf8d53e9c39","7899c3bad1c6d5ce"],"x":34,"y":299,"w":972,"h":262},{"id":"b813d119661b7826","type":"server-state-changed","z":"f4d699e3f5593b7b","g":"4702f2af3c981df9","name":"Kitchen PIR","server":"da3b2d1e.ad751","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.sensor_group_kitchen_motion_sensor","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"off","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"$entities('input_boolean.good_night_good_bye').state = 'on' ? 20 : 300","forType":"jsonata","forUnits":"seconds","ignorePrevStateNull":true,"ignorePrevStateUnknown":true,"ignorePrevStateUnavailable":true,"ignoreCurrentStateUnknown":true,"ignoreCurrentStateUnavailable":true,"outputProperties":[],"x":130,"y":360,"wires":[["7899c3bad1c6d5ce"],["836a9ec058e0f16f"]]},{"id":"d7ae93874e9e42d5","type":"api-call-service","z":"f4d699e3f5593b7b","g":"4702f2af3c981df9","name":"Turn on Kitchen Lights - Full","server":"da3b2d1e.ad751","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.light_group_kitchen_spots"],"data":"{\"brightness\":255,\"rgb_color\":[255,255,255]}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":820,"y":460,"wires":[[]]},{"id":"836a9ec058e0f16f","type":"api-current-state","z":"f4d699e3f5593b7b","g":"4702f2af3c981df9","name":"Light Level","server":"7e20b797.b28178","version":3,"outputs":2,"halt_if":"200","halt_if_type":"num","halt_if_compare":"lt","entity_id":"sensor.mqtt_sensor_samsung_kitchen_boiler_illuminance_lux","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":150,"y":440,"wires":[["3a22270b2b637ea5"],[]]},{"id":"3a22270b2b637ea5","type":"api-current-state","z":"f4d699e3f5593b7b","g":"4702f2af3c981df9","name":"Good-Bye-Good-Night","server":"7e20b797.b28178","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.good_night_good_bye","state_type":"str","blockInputOverrides":false,"outputProperties":[],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":370,"y":440,"wires":[["3981fbf8d53e9c39"],["58300163b07271ca"]]},{"id":"58300163b07271ca","type":"within-time-switch","z":"f4d699e3f5593b7b","g":"4702f2af3c981df9","name":"","nameInt":"","positionConfig":"b954ab15.fd5738","startTime":"07:00","startTimeType":"entered","startOffset":0,"startOffsetType":"none","startOffsetMultiplier":60000,"endTime":"23:00","endTimeType":"entered","endOffset":0,"endOffsetType":"none","endOffsetMultiplier":60000,"timeRestrictions":0,"timeRestrictionsType":"none","timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeOnlyOddWeeks":false,"timeOnlyEvenWeeks":false,"timeMonths":"*","timedatestart":"","timedateend":"","propertyStart":"","propertyStartType":"none","propertyStartCompare":"true","propertyStartThreshold":"","propertyStartThresholdType":"num","startTimeAlt":"","startTimeAltType":"entered","startOffsetAlt":0,"startOffsetAltType":"none","startOffsetAltMultiplier":60000,"propertyEnd":"","propertyEndType":"none","propertyEndCompare":"true","propertyEndThreshold":"","propertyEndThresholdType":"num","endTimeAlt":"","endTimeAltType":"entered","endOffsetAlt":0,"endOffsetAltType":"none","endOffsetAltMultiplier":60000,"withinTimeValue":"true","withinTimeValueType":"msgInput","outOfTimeValue":"false","outOfTimeValueType":"msgInput","tsCompare":"0","x":590,"y":480,"wires":[["d7ae93874e9e42d5"],["df5f749a45e913a9"]]},{"id":"df5f749a45e913a9","type":"api-call-service","z":"f4d699e3f5593b7b","g":"4702f2af3c981df9","name":"Turn on Kitchen Lights - Dimmed","server":"da3b2d1e.ad751","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.light_group_kitchen_spots"],"data":"{\"brightness\":5,\"rgb_color\":[255,255,255]}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":840,"y":520,"wires":[[]]},{"id":"3981fbf8d53e9c39","type":"api-call-service","z":"f4d699e3f5593b7b","g":"4702f2af3c981df9","name":"Turn on Kitchen Lights - Dimmed","server":"da3b2d1e.ad751","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.light_group_kitchen_spots"],"data":"{\"brightness\":2,\"rgb_color\":[255,255,255]}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":660,"y":400,"wires":[[]]},{"id":"7899c3bad1c6d5ce","type":"api-call-service","z":"f4d699e3f5593b7b","g":"4702f2af3c981df9","name":"Turn off Kitchen Lights","server":"da3b2d1e.ad751","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.light_group_kitchen_spots"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":360,"y":340,"wires":[[]]},{"id":"da3b2d1e.ad751","type":"server","name":"Home Assistant","version":4,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m"},{"id":"7e20b797.b28178","type":"server","name":"Home Assistant","version":4,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m"},{"id":"b954ab15.fd5738","type":"position-config","name":"","isValide":"true","longitude":"0","latitude":"0","angleType":"deg","timeZoneOffset":"99","timeZoneDST":"0","stateTimeFormat":"3","stateDateFormat":"12","contextStore":""}]
