Can someone explain how to format the light profiles csv works?
I am trying to achieve my lounge lamp always turn on at 75% brightness unless otherwise set. The bulb is a hue that has no ability to change colour temp. I have tried to follow the instructions online, but can’t get it to work.
The light profiles csv is in the same folder as config.ymal and I have this code so far.
I have also been trying to figure this out without any luck. Currently I use a blueprint called “Default turn-on brightness and color temperature for light(s)”, it works but I rather want to change something in a config file than creating automations.
Please let me know if you find a solution with the csv file.
You need to supply a valid value for the X/Y color values even if your light doesn’t support colors. They will just be ignored. Only the transition value is optional.
I’ve been struggling with this on and off for ages. All I want is to set lights to a preferred colour and brightness when turned on, rather than whatever values they were turned off at.
Here’s my light_profiles.csv contents (which is in same folder as config.yaml).
