I’ve got a problem I just can’t get my head around. I’ve got a script that I want to use to flash my lights red, when I’m out and motion is detected in the house, i.e. part of an Alarm type setup.
So on running the script to test, it flashes the light but does not change it to red. I’ve tried this with both the “RGB-Color” and “Color name” data types, with no difference, the light flashes white. I’m using Hue Colour Ambience bulbs by the way.
But then strangely, after the test, when I turn the light on normally, it comes on Red. What am I missing please? Here’s the script, with the rgb_color type: -
service: light.turn_on
color_name: blue
entity_id: light.mondo_wand
flash: long
It works. That the color go to blue and flashing.
But I have one problem, if the light is on before the script start for example in color green. After the flashing is the color still blue. How can I make it show the old color again after flashing?
I do this with a few automations. At the end of the automation just restore the color before turning them off. The color change persists and then when you turn on the color is there.
It’s that our when you have a switch turn them on you set them to soft white or whatever you want.
Here is an example for my water alarm
For an alarm though I would suggest making an input Boolean for alarm tripped and then do two automations. One to trigger it and one to clear it.
But if so, you turn on the light afterwards, with a defined color, not with the color that was on before or?
And if the light are off before it turns on the alarm, after the alarm, the light is also on or?
What I want is:
if the light is off, the alarm come and put on the light in blue, after the alarm, the light goes off.
if the light is on for example green or a other color, the alarm come and the light switch to blue, after the alarm, the light goes back to the color before.
Yeah I keep it simple and use conditions but if you want that kind of activity, then you need to use scenes. You would fire the automation, create a scene, do your light blink, then restore the scene afterwards. That would be a way to get to a single automation without having multiple that are condition based.
