Tsar
(Christian)
October 30, 2022, 6:40am
1
I created these templates to switch on/off my lights :
light.yaml
lights:
lights_hallway:
friendly_name: "Lichten gang"
turn_on:
service: homeassistant.turn_on
entity_id: switch.do_not_use_verlichting_hallway
turn_off:
service: homeassistant.turn_off
switch.yaml
- platform: command_line
switches:
do_not_use_verlichting_hallway:
command_on: 'curl "http://192.168.1.3:80/postEvent.html?action=input&STM=0&MOD=5&CHA=0&EVT=3"'
command_off: 'curl "http://192.168.1.3:80/postEvent.html?action=input&STM=0&MOD=5&CHA=1&EVT=3"'
This works perfect, except that the state is lost when restarting home assistant (state is off even if light is on).
I could make 2 automations to save and restore the states in combination with helpers, but wonder if there is a better way.
You would need to provide âvalue_templateâ to provide the state on restart. Can you read the state from the switch?
Tsar
(Christian)
October 30, 2022, 5:33pm
3
Unfortunately notâŚ
For the moment I have this to save the status :
alias: Status verlichting bijhouden
description: ""
- platform: state
entity_id:
- light.lights_hallway
condition: []
- if:
- condition: template
value_template: "{{ states(trigger.entity_id) == 'on' }}"
then:
entity_id: input_boolean.toggle_status_lichten_{{ trigger.id }}
else:
- service: input_boolean.turn_off
mode: queued
max: 10
And this to restore it :
description: ""
mode: single
- platform: homeassistant
event: start
condition: []
- if:
- condition: state
entity_id: input_boolean.toggle_status_lichten_gang
state: "on"
then:
- service: light.turn_on
data: {}
entity_id: light.lights_hallway
else:
- service: light.turn_off
data: {}
....and all other lights...
This works fine for all the normal lights wich can only be on or off, so when a light is on and I switch it on again nothing changes. But for my dimmer lights I should have the possibility to change the status of the light without actualy switching the light on (cause it is on and donât know how it is dimmed). Is that possible ?
Iâve needed something similar before, and I used MQTT with retain so that state is restored on restart. Something along the lines of:
light:
- name: "Dummy light 1"
schema: json
state_topic: "mb/ha/config/mqtt.yaml/dummy/1/state"
command_topic: "mb/ha/config/mqtt.yaml/dummy/1/set"
brightness: true
qos: 0
optimistic: true
and then an automation trigger that handles the command and sends the state topic (although I use Node Red):
automation:
- platform: mqtt
- service: script.on_off
state: {{ value_json }}
- service: mqtt.publish
payload_template: {{ value_json }}
retain: true
You could get rid of the extra âon_offâ script by having the logic in the automation and using âswitch.turn_on/offâ. One benefit of this approach is you can have one automation for many lights/switches by using wildcards in the topics and âtopic_templateâ for state (although Iâm not sure how you can get the incoming topic in YAML).
This approach would also work with dimmers as you could include the brightness in the MQTT state topic and pull it back out using âbrightness_value_templateâ or any of the other â*_templateâ options.
Note that I have not tested the above as Iâve converted my Node Red code to YAML equivalent.
Just want to add you can simplify your action to make it less verbose and leverage templating more:
- service: light.turn_{{ 'on' if is_state('input_boolean.toggle_status_lichten_gang', 'on') else 'off')
Tsar
(Christian)
October 31, 2022, 7:39am
7
I found this, wich seems to be what I need : REST API | Home Assistant Developer Docs
So I created this :
turn_lights_hallway_on:
url: http://192.168.1.6:8123/api/states/light.lights_hallway
method: POST
headers:
authorization: 'Bearer ABC'
content-type: 'application/json'
payload: '{"state":"on"}'
I replace ABC by a Long-Lived Access Token.
And replaced in my automation the light.turn_on by this :
- service: rest_command.turn_lights_hallway_on
data: {}
But I get an error :
Logger: homeassistant.components.http.ban
Source: components/http/ban.py:84
Integration: HTTP (documentation, issues)
First occurred: 08:37:12 (1 occurrences)
Last logged: 08:37:12
Login attempt or request with invalid authentication from 192.168.1.6 (192.168.1.6). Requested URL: â/api/states/light.lights_hallwayâ. (HomeAssistant/2022.10.5 aiohttp/3.8.1 Python/3.10)
Logger: homeassistant.components.rest_command
Source: components/rest_command/init .py:137
Integration: RESTful Command (documentation, issues)
Error. Url: http://192.168.1.6:8123/api/states/light.lights_hallway . Status code 401. Payload: bâ{âstateâ:âonâ}â
What did I wrong ?
Tsar
(Christian)
November 1, 2022, 9:14pm
8
Found it : seems I didnât copy the whole token
