My wife uses the light switch again and again to switch off the light. When the light is turned back on, the HassIO will not recognize it and the last status (on or off) will still be displayed. Is there a solution for the status of the lamps to match?
I found that if my lights are toggled at the wall switch the system does update the status correctly, but takes around a minute to do so (to change from unavailable to the correct state).
I’ve just told my wife that if she keeps on pressing the wall switch then she has to deal with the delay in the colour/brightness automation…
Yes my wife use the hardwired switch. I use MQTT with zigbee2mqtt on HassIO on a Pi.
Hassio does not recognize that the lamp is off or the device is unreachable. Also do not wait for a long time. So he does not ask the status of the devices regularly.
Is there a script that queries the status of the devices regularly?
