Light: Switch (Any) + Motion Sensor (Unified Logic with Manual Mode & Lockout)
A single, fully unified blueprint for smart lighting control that seamlessly combines a Motion Sensor and ANY Switch/Button/Remote (Zigbee, ZHA, Z-Wave, MQTT, or State triggers).
It solves the classic problem of manual light overrides conflicting with motion sensors.
:glowing_star: Features
  • Manual Mode (Switch Override): Turning on the light via switch enters Manual Mode. The light will stay on until X duration after the LAST detected motion (defaults to 2 hours). If motion occurs again, the timeout timer automatically resets. If no motion occurs at all, it stays on until manually turned off.
  • Auto Mode (Motion Sensor): If the light is turned on purely by motion, it automatically turns off M minutes after motion stops.
  • Sensor Lockout / Debounce: Manual turn-off via switch activates an N-minute lockout window (defaults to 2 minutes). During this window, motion will not turn the light back on β€” giving you time to walk out of the room without triggering the sensor.
  • Single Timer Efficiency: Uses just one helper timer for both the manual timeout and the sensor lockout, as their states never overlap.
  • HA Restart Persistence: Automatically restores the manual timeout state if Home Assistant restarts while Manual Mode is active.
:gear: Prerequisites (Create Helpers First)
Before creating an automation from this blueprint, create two helpers via Settings β†’ Devices & Services β†’ Helpers:
  1. input_boolean (e.g., input_boolean.hallway_manual_mode) β€” Flag for tracking manual mode.
  2. timer (e.g., timer.hallway_light) β€” Shared timer for manual timeout & lockout.
:clipboard: Links & Installation
You can import this blueprint directly using the button at the top of this post, or inspect the source file directly on GitHub:
  • GitHub Repository: Light switch motion unified.yaml
  • Raw YAML Link: https://raw.githubusercontent.com/olegchumakov/ha_blueprints/refs/heads/main/Light%20switch%20motion%20unified.yaml
