Just getting into Node-Red and I’ve started building a dashboard.
At the moment, I have one bulb in there with an on/off switch and a slider for the brightness.
The problem is that they aren’t in sync. So if I set the brightness to zero, the switch stays on. If I set the brightness to 50% and then switch the light off, the brightness stays at 50%
Is there a way to sync the 2 entities?
This is what the flow looks like:
This is the flow:
"id": "ef1fe1e3.2f499",
"type": "tab",
"label": "Dashboard",
"disabled": false,
"info": ""
"id": "10bf32fd.4c497d",
"type": "ui_slider",
"z": "ef1fe1e3.2f499",
"name": "",
"label": "Sofa lamp",
"tooltip": "",
"group": "c4803627.12f8e8",
"order": 0,
"width": 0,
"height": 0,
"passthru": true,
"outs": "all",
"topic": "",
"min": 0,
"max": "100",
"step": "10",
"x": 110,
"y": 140,
"wires": [
"cc62b54f.5269f8"
"id": "cc62b54f.5269f8",
"type": "function",
"name": "",
"func": "var newMsg = { \n payload:{ \n \"data\":{ \n \"brightness_pct\":msg.payload,\n \"transition\":\"3\"\n }\n }\n}\nreturn newMsg;",
"outputs": 1,
"noerr": 0,
"x": 270,
"y": 140,
"wires": [
"6a3ad024.d705c"
"id": "6a3ad024.d705c",
"type": "api-call-service",
"name": "",
"server": "96ebf4f8.6d0e78",
"version": 1,
"debugenabled": false,
"service_domain": "light",
"service": "turn_on",
"entityId": "light.sofa_lamp",
"data": "",
"dataType": "json",
"mergecontext": "",
"output_location": "",
"output_location_type": "none",
"mustacheAltTags": false,
"x": 470,
"y": 140,
"wires": [
"id": "30cc0233.3cb30e",
"type": "ui_switch",
"name": "",
"tooltip": "",
"order": 1,
"width": "2",
"height": "2",
"passthru": true,
"decouple": "false",
"topic": "",
"style": "",
"onvalue": "true",
"onvalueType": "bool",
"onicon": "fa-lightbulb-o fa-4x",
"oncolor": "#ff9900",
"offvalue": "false",
"offvalueType": "bool",
"officon": "fa-lightbulb-o fa-4x",
"offcolor": "#ffffff",
"x": 290,
"y": 220,
"wires": [
"8df17538.1785e8"
"icon": "font-awesome/fa-lightbulb-o"
"id": "8df17538.1785e8",
"name": "Sofa toggle",
"version": 1,
"service": "toggle",
"data": "",
"dataType": "json",
"mergecontext": "",
"x": 450,
"y": 220,
"wires": [
"id": "b334bd9c.5672d",
"type": "switch",
"name": "",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "cont",
"v": "on",
"vt": "str"
"t": "cont",
"v": "off",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 390,
"y": 420,
"wires": [
"6608088e.2a22a8"
"cb2f4e1d.f3f4f"
"id": "c84951da.617fd",
"type": "server-state-changed",
"name": "",
"version": 1,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "light.sofa_lamp",
"entityidfiltertype": "exact",
"outputinitially": false,
"state_type": "str",
"haltifstate": "",
"halt_if_type": "str",
"halt_if_compare": "is",
"outputs": 1,
"output_only_on_state_change": true,
"x": 140,
"y": 420,
"wires": [
"b334bd9c.5672d",
"2c75a648.e2320a"
"id": "6608088e.2a22a8",
"name": "Sofa on",
"version": 1,
"data": "",
"dataType": "json",
"mergecontext": "",
"x": 580,
"y": 360,
"wires": [
"id": "2c75a648.e2320a",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"x": 410,
"y": 540,
"wires": []
"id": "cb2f4e1d.f3f4f",
"name": "Sofa off",
"version": 1,
"service": "turn_off",
"data": "",
"dataType": "json",
"mergecontext": "",
"x": 580,
"y": 420,
"wires": [
"id": "c4803627.12f8e8",
"type": "ui_group",
"z": "",
"name": "Lounge",
"tab": "f8f5c1b4.1a334",
"order": 1,
"disp": false,
"width": "6",
"collapse": false
"id": "96ebf4f8.6d0e78",
"type": "server",
"z": "",
"name": "Home Assistant",
"addon": true
"id": "f8f5c1b4.1a334",
"type": "ui_tab",
"z": "",
"name": "Home",
"icon": "dashboard",
"disabled": false,
"hidden": false
