Just installed a zen26 tonight to control my garage lights. Since it shows up as a switch and not a light I created a template. I’ve since discovered that if I control the light with the physical switch or the actual switch in HA it does not update the state of the light template. However I can control the switch with the template just fine and will update state when using that.
I’ll have to look into the other template. Now as far as this switch template it does work for the most part, and two other templates work perfectly that control other lights. And with this one I can control the actual light using the template. It even updates when using it. It just isn’t being updated when the switch it’s self is used.
If you mark this thread as solved by selecting the answer which gave you the solution, other members will not jump in to try to help (like I just did) AND the topic will be useful for others having a similar issue.
