I’m reading the docs for setting up a light template and I’m having a hard time with the Brightness variable.
set_level:
service: script.theater_lights_level
brightness: "{{ brightness }}"
Is there an example of script.theater_lights_level that can be referenced so I can see the syntax of the script the template is calling? The template is passing the user input as a variable “brightness”, I assume?
In my script.brightness I have it like this:
- type: turn_on
device_id: X
entity_id: light.theatre_sconces
domain: light
brightness_pct: "{{ brightness }}"
Getting error:
Script Unavailable, Actions: expected float for dictionary value @ data[‘brightness_pct’]
I was going to setup a value template on the script, but it just seems like my syntax is simply wrong.
