sn33ky
1
I’m wanted to create a automation that turns the computer light on when the computer is running. Better for the eyes
I added a ping to check if my computer has been turned on. This sensors is working:
binary_sensor:
- platform: ping
host: 192.168.1.100
scan_interval: 15
Now i made a automation:
- id: '1597745411283'
alias: Woonkamer computerlamp uit
description: ''
- device_id: deadfe91fb3b4032a33de1ebc64a9020
domain: switch
entity_id: switch.computer
platform: device
type: turned_off
condition: []
- data:
transition: 15
entity_id: light.lumi_lumi_light_aqcn02_09892a04_level_light_color_on_off
service: light.turn_off
mode: restart
But this is not working and the light is not going on or off.
What am i doing wrong?
Those device triggers are horrendously messy, as are the rest of the ui generated automations…
platform: state
service_template: "light.turn_{{ trigger.to_state.state }}"
transition: 15
(this assumes that switch.computer is a thing, because the code you pasted was for a binary sensor)
sn33ky
3
Yup, i create my automatons mostly off the UI. But i’m slowly learning the YAML way, and you also helped me a little bit with the learning
And thanks. This does the trick. Although i had indeed a wrong device selected. but changed that to the binary sensor
alias: Woonkamer computerlamp aan/uit
- entity_id: binary_sensor.computerping
platform: state
- data:
transition: 15
service_template: light.turn_{{ trigger.to_state.state }}
mode: single
sn33ky
4
Another question: I want to set the brightness from the light to about 70% when going on. But when i add:
brightness_pct: 70
it is not turning off anymore.
