I’m trying to make a simple turn on light transition without using the transition node or any loops.
Just Service Turn on Light and with this in the expression field.
As far as I understand this should increase the lamp to full brightness within 30 seconds.
What happens is that it ignores the transition and just sets the lamp to 100% right away.
Thanks in advance for any solutions?
when I create an automation and choose this device, transition is not available so I guess you are right. It doesn’t support it.
When I choose another lamp I can see transition as an alternative.
Its a cheap Deltaco Smart RGB Wake-up Light added through tuya integration so that makes sense I guess. Well I guess im stuck with the transition node in node red or looping it.
