Hi all…
I just bought one of these to test:
Installed ok, and linked up to HA,
HOWEVER, the lights when on 100% are not as bright as the standard (non-smart) switch, has anyone come across this issue?
thanks Mark
Hello MarkDunham,
That thing is 1.5 amp. If you have a lot of LED’s maybe it’s limiting things to protect itself. If just might be designed that way as well.
Hi, this was on a small room, 3 LED lights, so something else not right. maybe the internal circuitry is not really up for it… shame as it’s marketed for this type of use and is economical and small to fit into a 6 hole plate
