Lights delay with Motion Sensor Delay
Setup: Lutron Caseta Motion Sensor
Lutron Caseta Dimmer
Lutron Caseta Switch
Lutron Caseta Pro Bridge with HA VM + Node Red
Hello, I’m having a slight issue with my setup, when controlling the lights in my bathroom with the Lutron App or physically they light up instantly and I’ve also tried using the motion sensor outside of HA and it worked just fine. However after installing HA and Node-Red( Newbie) I noticed that there is usually about 1.5-2 seconds delay after entering the bathroom before the lights light up. I was wondering if you guys could tell me if my flow could be responsible for it.
Essentially I am trying to have only the vanity lights turn on during the middle of the night or else have it also check if it’s day light, if it is then nothing turns on, otherwise both lights turn on.
Thank you
I do have a similar issue with zha events. Particularly I noticed it with a switch from osram I recently purchase. When listening to events in HA, events trigger instantly. However there’s a random delay when I listen for those events with the events: all node… Hopefully somebody will be able to shed light to this matter.
