Lights go off or on in sequence
Does anyone recognize this ? Here’s some info, I have several sealing lights made up of 4 individual Philips HUE bulbs that I joined in a group. The group has it’s own entity. Before the Sept 24 HA update, whenever I issued an ‘on’ trigger, all lamps in the group turned on simultaneously. Now, after the update, they turn on in a random sequence with a noticeable delay. Sometimes one after another, some 2 ‘on’ and the others follow with a small delay. The same goes for turning a group ‘OFF’. It applies to all light groups I have. individual lights have a small but noticeable delay after an ‘ON’ trigger as well. Resetting HA or the host had no effect.
Any input is welcome
This has been mentioned a few times before in the past and I doubt it has anything to do with the latest update.
In your particular case, you’re lucky in the sense that creating a zigbee group (instead of a HA group) should work around the issue.
