Lights issue
Hi guys
I am new to home assistant and managed to pair up my Philips Hue lights, but am struggling to get the automation working for them to come on 15 mins before sunset. I have tried various things, but cannot get it right. This is the code I have currently. The group of lights I want to come on are called light.kitchen when I look at the entity id in states.
automation 2:
alias: Turn on light when sun sets
initial_state: True
hide_entity: True
platform: sun
event: sunset
offset: “-00:15:00”
condition:
condition: state
entity_id: group.all_devices
state: ‘home’
service: homeassistant.turn_on
entity_id: light.kitchen
@andyp85
Can you re-post your automation using the code tags </> for formatting?
Can you send a screen shot of the entity with its attributes?
Did you put these lights in an actual group making them group.kitchen_lights or something along those lines?
Here’s one issue.
Try this:
service: light.turn_on
@firstof9
I usually use homeassistant.turn_on to turn on a list of different entities from different domains.
I would think it would work for a single entity but it is certainly worth a shot @andyp85 .
The only difference is light.turn_on allows you to specify a brightness/color, but yes you could technically use homeassistant.turn_on
I figure using the light service since it’s specifically turning on a light, less processing time/load.
@andyp85’s issue may be that all the devices in the group are not flagged as “home”.
Thanks for the responses. I tried changing to light.turn_on but it made no difference. Images attached of what I have in the configuration.yaml file for the lights, the attribute and the other bit I have in my configuration file which put displayed the light groups I had set up in my hue app.
Any errors in the log about the hue?
I dont recognize the is_hue_group: true variable
No errors relating to Hue in the home-assistant.log file. Just 3 lines regarding malformed XML (whatever they mean)
I got the is_hue _group line from the following guide >>> How do you use discover_scenes.py to find hue groups & scenes?
In my entities I don’t have anything called group.all_devices which made me think maybe that line is incorrect. But I have group.all_lights and group.all_automations . I have tried these and it didn’t work with those either
is_hue_group: true is an attribute of the group not a variable for the hue component.
You might try removing it.
I assume you followed all these steps?
Thanks I have removed is_hue_group: true
I tried following those steps, but keep getting an error saying the id I am entering for the lights is invalid. I assume its the long unique ID I use for each light in place of the [“1”, “2”, “3”] in the guide? I find the guides are a bit vague for the beginner.
If you don’t have a group called group.all_devices per your automation, then it’s always going to return False and not trigger your lights.
Try removing
condition:
  condition: state
  state: 'home'
Removing that has done the trick. Thanks very much for that. I did wonder about that section and think it could be a bit clearer in the guides for the beginner, but maybe that’s just me!
I guess that condition section is only needed if you are adding another condition for the lights coming on, as well as the sun setting? (i.e. being home at the time)
Correct, you could set a condition such as it lists when all cell phones are in a state of “home” then the lights turn on, otherwise stay off.
