So I’m trying to use an automation, which turns on light, when there is a movement in a timeframe.
The timeframe should be:
After: Sunset -2 hrs
Before: 10:00 pm
There is one more filter to check if the bedroom tv is off. If it’s on, it means, we’re already in the bed, and I would like another dimmed automation to run then.
For some reason, the Sun state isn’t working as expected, because if I remove that, the automation runs properly.
The code is:
alias: 2. Kitchen afternoon movement lights on
entity_id: binary_sensor.motion_sensor_158d0002047cb7
platform: state
to: ‘on’
condition:
before: ‘22:00’
condition: time
before: sunset
before_offset: 02:00:00
condition: sun
condition: state
entity_id: media_player.bedroom_tv
state: ‘off’
looking at the example docs, it seems you might have missed out some quotes, so not sure if that is doing it,
condition:
condition: sun
after: sunset
# Optional offset value - in this case it must from -1 hours relative to sunset, or after
after_offset: "-01:00:00"
I’m not sure it is the problem.
If I edit the yaml file, and then reopen it in the automation editor, the quotes dissappear.
they are removed from the yaml also.
but since you mentioned it, I looked up for the documentation
and probably this is the missunderstood part.
according to this, my configuration should look like this.
before: sunset
before_offset: “-02:00:00”
condition: sun
You said you want to trigger AFTER the sunset and BEFORE 10pm
one note here: after sunset but 2 hours before sunset is a bit tricky.
Lets talk numbers here: Sunset is at 19:00. 2 hours before that is 17:00. That means that you want to trigger AFTER 17:00 and before 22:00.
that is why you have to use:
after_offset: ’ -02:00:00’
I’ve tried this, and worked. (changed to 8 hours just to see if the sun condition works)
If it won’t work, will try your solution. I think the main problem was that I didn’t know, I have to use -02:00:00.
The ‘and’ is something that I like to use when i have multiple conditions. It works by default like that without using it. It is quicker when I want to test automations by just changing it to “or”.
If you had multiple conditions but you only wanted one of them to be true, then you can change the “and” to an “or”.
Good luck with your automation.
If I remember correctly that could be a problem, instead of using after sunset, better use sun elevation.
Because 22:00 is today but 00:01 is other day
I am not sure if you can have a sunset at 00:01. Usually the sunset is at around 19:00-20:00
That being said, the automation will always be at the same day.
@argykaraz is on the correct track and his template should work. I have seen issues using ‘and’ at the top level of conditions. One thing to note, the 'and’ed conditions are redundant at the top level. Providing condition with a list of conditions will ‘and’ them all together by default.
- id: '1537982716650'
alias: '2. Kitchen afternoon movement lights on'
- platform: state
to: 'on'
condition:
- condition: sun
after: sunset
after_offset: '-02:00:00'
- condition: time
before: '22:00:00'
- condition: state
state: 'off'
- service: scene.turn_on
entity_id: scene.konyha
