Lights turn off - no user action
Hi, I have a question.
I have 5 IKEA light bulbs, connected in 1 Deconz Group, and 1 IKEA switch, setup in Phoshon with turn on/off action.
But it look like, when Deconz reloads, then the light turns off, but only this one group. and I have 30+ bulbs, and 10 groups.
Deconz Log:
2:08:42:310 Current channel 20
22:08:42:318 Device TTL 960 s flags: 0x7
22:08:42:695 DeviceAnnce of SensorNode: 0x000D6FFFFED65401 [1]
22:08:42:905 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:08:43:051 ZCL attribute report 0x04CF8CDF3C82324C for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:08:46:783 ZCL attribute report 0x0017880104B71CE8 for cluster: 0x0402, ep: 0x02, frame control: 0x08, mfcode: 0x0000
22:08:47:562 ZCL attribute report 0x0017880104B71CE8 for cluster: 0x0406, ep: 0x02, frame control: 0x08, mfcode: 0x0000
22:08:50:328 Bind response success for 0x04cf8cdf3c79d27f ep: 0x01 cluster: 0x0B04
22:08:50:421 ZCL configure reporting rsp seq: 129 0x04CF8CDF3C79D27F for ep: 0x01 cluster: 0x0B04 attr: 0x050B status: 0x8C
22:08:50:422 ZCL configure reporting rsp seq: 129 0x04CF8CDF3C79D27F for ep: 0x01 cluster: 0x0B04 attr: 0x0505 status: 0x86
22:08:50:471 Bind response success for 0x04cf8cdf3c823320 ep: 0x01 cluster: 0x0B04
22:08:50:472 skip configure report for cluster: 0x0B04 attr: 0x050B of node 0x04CF8CDF3C823320 (seems to be active)
22:08:50:550 ZCL configure reporting rsp seq: 130 0x04CF8CDF3C823320 for ep: 0x01 cluster: 0x0B04 attr: 0x0505 status: 0x86
22:08:50:721 ZCL attribute report 0x0017880104B71CE8 for cluster: 0x0406, ep: 0x02, frame control: 0x08, mfcode: 0x0000
22:08:53:298 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:08:54:773 skip binding for attribute reporting of ep: 0x00 cluster 0x1000 (end-device might sleep)
22:08:54:819 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:08:54:907 ZCL attribute report 0x04CF8CDF3C823320 for cluster: 0x0702, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:08:57:831 Bind response success for 0x04cf8cdf3c82324c ep: 0x01 cluster: 0x0B04
22:08:57:945 ZCL configure reporting rsp seq: 133 0x04CF8CDF3C82324C for ep: 0x01 cluster: 0x0B04 attr: 0x050B status: 0x8C
22:08:57:946 ZCL configure reporting rsp seq: 133 0x04CF8CDF3C82324C for ep: 0x01 cluster: 0x0B04 attr: 0x0505 status: 0x86
22:08:58:147 Bind response success for 0x04cf8cdf3c8234d5 ep: 0x01 cluster: 0x0B04
22:08:58:248 ZCL configure reporting rsp seq: 134 0x04CF8CDF3C8234D5 for ep: 0x01 cluster: 0x0B04 attr: 0x050B status: 0x8C
22:08:58:249 ZCL configure reporting rsp seq: 134 0x04CF8CDF3C8234D5 for ep: 0x01 cluster: 0x0B04 attr: 0x0505 status: 0x86
22:08:59:245 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:00:760 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:01:474 ZCL attribute report 0x00158D00039409CB for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
22:09:01:493 ZCL attribute report 0x00158D00039409CB for cluster: 0x0406, ep: 0x01, frame control: 0x18, mfcode: 0x0000
22:09:02:175 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:03:802 ZCL attribute report 0x00158D0003981932 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
22:09:03:812 ZCL attribute report 0x00158D0003981932 for cluster: 0x0406, ep: 0x01, frame control: 0x18, mfcode: 0x0000
22:09:05:553 ZCL attribute report 0x000B57FFFED602B1 for cluster: 0x0008, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:08:773 skip binding for attribute reporting of ep: 0x00 cluster 0x1000 (end-device might sleep)
22:09:09:103 ZCL attribute report 0x0017880104B71CE8 for cluster: 0x0406, ep: 0x02, frame control: 0x08, mfcode: 0x0000
22:09:09:319 verified group capacity: 23 and group count: 2 of LightNode 0x0017880104b8a935
22:09:09:320 0x0017880104b8a935 found group 0xFFF0
22:09:09:321 0x0017880104b8a935 found group 0x0009
22:09:09:626 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:11:038 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:11:304 ZCL attribute report 0x000B3CFFFEFADE85 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:11:546 ZCL attribute report 0x90FD9FFFFE6E532D for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:11:808 ZCL attribute report 0x086BD7FFFE051DF2 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:11:986 ZCL attribute report 0x086BD7FFFE2B1FA9 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:15:907 ZCL attribute report 0x588E81FFFE2202BF for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:16:058 ZCL attribute report 0xEC1BBDFFFE393197 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:16:208 ZCL attribute report 0x680AE2FFFEF0AA05 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:16:267 ZCL attribute report 0xEC1BBDFFFE4D17DD for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:25:243 ZCL attribute report 0x04CF8CDF3C823320 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:30:044 unknown neighbor 0x90FD9FFFFE0CBA00 (0xD577), lqi: 223, rssi: -66
22:09:31:370 ZCL attribute report 0x04CF8CDF3C8234D5 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:31:434 Bind response success for 0x04cf8cdf3c8234d5 ep: 0x01 cluster: 0x0B04
22:09:31:529 ZCL configure reporting rsp seq: 142 0x04CF8CDF3C8234D5 for ep: 0x01 cluster: 0x0B04 attr: 0x050B status: 0x8C
22:09:31:530 ZCL configure reporting rsp seq: 142 0x04CF8CDF3C8234D5 for ep: 0x01 cluster: 0x0B04 attr: 0x0505 status: 0x86
22:09:33:945 ZCL attribute report 0xEC1BBDFFFE393197 for cluster: 0x0008, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:34:647 ZCL attribute report 0xEC1BBDFFFE4D17DD for cluster: 0x0008, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:38:841 ZCL attribute report 0x0017880104B71CE8 for cluster: 0x0406, ep: 0x02, frame control: 0x08, mfcode: 0x0000
22:09:38:974 ZCL attribute report 0x00158D00063DDCAD for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
22:09:38:984 ZCL attribute report 0x00158D00063DDCAD for cluster: 0x0406, ep: 0x01, frame control: 0x18, mfcode: 0x0000
22:09:39:090 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:40:249 ZCL attribute report 0x000B57FFFE88FBE4 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:40:262 ZCL attribute report 0x90FD9FFFFE6F5AE5 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:40:275 ZCL attribute report 0x000B57FFFE88FDF9 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:40:292 ZCL attribute report 0x000B57FFFEB06D4C for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:40:299 unknown neighbor 0x90FD9FFFFE0CBA00 (0xD577), lqi: 231, rssi: -65
22:09:40:301 ZCL attribute report 0x90FD9FFFFE0CBA00 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:40:494 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:42:291 Current channel 20
22:09:42:299 Device TTL 900 s flags: 0x7
22:09:43:518 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:44:584 ZCL attribute report 0x04CF8CDF3C82324C for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:44:586 discard double entry in binding queue (size: 3) for for 0x04CF8CDF3C82324C, cluster 0x0B04
22:09:46:462 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:56:302 ZCL attribute report 0x04CF8CDF3C823320 for cluster: 0x0702, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:56:641 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:09:58:140 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:10:01:319 dev /dev/ttyAMA0
22:10:01:320 GW firmware version: 0x26660700
22:10:01:321 GW firmware version is up to date: 0x26660700
22:10:02:590 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:10:03:366 verified group capacity: 255 and group count: 2 of LightNode 0xec1bbdfffe4d17dd
22:10:03:367 0xec1bbdfffe4d17dd found group 0xFFF0
22:10:03:368 0xec1bbdfffe4d17dd found group 0x000C
22:10:03:992 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:10:04:895 ZCL attribute report 0x00158D0003981932 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
22:10:04:908 ZCL attribute report 0x00158D0003981932 for cluster: 0x0406, ep: 0x01, frame control: 0x18, mfcode: 0x0000
22:10:05:410 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:10:06:818 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:10:08:227 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:10:08:984 ZCL attribute report 0x000B57FFFEC0E3EE for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:10:08:991 ZCL attribute report 0x90FD9FFFFE083E06 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:10:09:131 ZCL attribute report 0x000B57FFFE32EB9B for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:10:09:159 unknown neighbor 0x000B57FFFE349F5C (0x7C19), lqi: 183, rssi: -71
22:10:09:161 ZCL attribute report 0x000B57FFFE349F5C for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:10:09:622 ZCL attribute report 0x90FD9FFFFED31774 for cluster: 0x0001, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:10:09:772 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:10:11:055 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:10:11:861 ZCL attribute report 0x0017880104B71CE8 for cluster: 0x0406, ep: 0x02, frame control: 0x08, mfcode: 0x0000
22:10:12:067 ZCL attribute report 0x680AE2FFFEC4EB94 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:10:12:595 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
22:10:15:397 ZCL attribute report 0x04CF8CDF3C823B75 for cluster: 0x0B04, ep: 0x01, frame control: 0x08, mfcode: 0x0000
HA LOGBOOK:
Køkken bord turned off
22.09.40 - 7 minutes ago
Køkken_bord_4 turned off
Køkken_bord_5 turned off
Køkken_bord_2 turned off
Køkken_bord_3 turned off
Køkken_bord_1 turned off
Any Clues where to find the “bug” ???
