Both Bulbs are ZW7101 (Embrighten bulb) and the door sensor is a Linear WADWAZ-1
In the log, I am seeing the following:
Door Open:
2017-10-23 09:01:00.380 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x04, 0x03, 0x03, 0x20, 0x01, 0xff, 0x28
2017-10-23 09:01:00.381 Detail,
2017-10-23 09:01:00.383 Info, Node003, Received Basic set from node 3: level=255. Sending event notification.
2017-10-23 09:01:00.386 Detail, Node003, Notification: NodeEvent
2017-10-23 09:01:00.412 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x20, 0x01, 0xff, 0x2c
2017-10-23 09:01:00.426 Detail,
2017-10-23 09:01:00.430 Info, Node003, Received Basic set from node 3: level=255. Sending event notification.
2017-10-23 09:01:00.434 Detail, Node003, Notification: NodeEvent
2017-10-23 09:01:00.473 Detail, Node003, Received: 0x01, 0x10, 0x00, 0x04, 0x04, 0x03, 0x0a, 0x71, 0x05, 0x07, 0xff, 0x00, 0xff, 0x07, 0x02, 0x00, 0x00, 0x90
2017-10-23 09:01:00.485 Detail,
2017-10-23 09:01:00.488 Info, Node003, Received Alarm report: type=7, level=255, sensorSrcID=0, type:Burglar event:2, status=255
2017-10-23 09:01:00.490 Detail, Node003, Refreshed Value: old value=7, new value=7, type=byte
2017-10-23 09:01:00.491 Detail, Node003, Changes to this value are not verified
2017-10-23 09:01:00.493 Detail, Node003, Refreshed Value: old value=0, new value=255, type=byte
2017-10-23 09:01:00.495 Detail, Node003, Changes to this value are not verified
2017-10-23 09:01:00.497 Detail, Node003, Refreshed Value: old value=0, new value=0, type=byte
2017-10-23 09:01:00.499 Detail, Node003, Changes to this value are not verified
2017-10-23 09:01:00.502 Detail, Node003, Refreshed Value: old value=2, new value=2, type=byte
2017-10-23 09:01:00.503 Detail, Node003, Changes to this value are not verified
2017-10-23 09:01:00.506 Detail, Node003, Notification: ValueChanged
2017-10-23 09:01:00.591 Detail, Node003, Notification: ValueChanged
2017-10-23 09:01:00.752 Detail, Node003, Notification: ValueChanged
2017-10-23 09:01:00.907 Detail, Node003, Notification: ValueChanged
2017-10-23 09:01:01.040 Detail, Node003, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x03, 0x0a, 0x71, 0x05, 0x07, 0xff, 0x00, 0xff, 0x07, 0x02, 0x00, 0x00, 0x94
2017-10-23 09:01:01.042 Detail,
2017-10-23 09:01:01.045 Info, Node003, Received Alarm report: type=7, level=255, sensorSrcID=0, type:Burglar event:2, status=255
2017-10-23 09:01:01.051 Detail, Node003, Refreshed Value: old value=7, new value=7, type=byte
2017-10-23 09:01:01.052 Detail, Node003, Changes to this value are not verified
2017-10-23 09:01:01.054 Detail, Node003, Refreshed Value: old value=255, new value=255, type=byte
2017-10-23 09:01:01.058 Detail, Node003, Changes to this value are not verified
2017-10-23 09:01:01.059 Detail, Node003, Refreshed Value: old value=0, new value=0, type=byte
2017-10-23 09:01:01.061 Detail, Node003, Changes to this value are not verified
2017-10-23 09:01:01.063 Detail, Node003, Refreshed Value: old value=2, new value=2, type=byte
2017-10-23 09:01:01.065 Detail, Node003, Changes to this value are not verified
2017-10-23 09:01:01.069 Detail, Node003, Notification: ValueChanged
2017-10-23 09:01:01.199 Detail, Node003, Notification: ValueChanged
2017-10-23 09:01:02.324 Detail, Node003, Notification: ValueChanged
2017-10-23 09:01:02.473 Detail, Node003, Notification: ValueChanged
Door Closed:
2017-10-23 09:01:16.404 Detail, Node010, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x0a, 0x02, 0x84, 0x07, 0x78
2017-10-23 09:01:16.406 Detail,
2017-10-23 09:01:16.408 Info, Node010, Received Wakeup Notification from node 10
2017-10-23 09:01:16.410 Info, Node010, Node 10 has been marked as awake
2017-10-23 09:01:16.412 Detail, Node010, Queuing (WakeUp) WakeUpCmd_NoMoreInformation (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x84, 0x08, 0x25, 0xff, 0xbb
2017-10-23 09:01:16.414 Detail, Node010, Notification: Notification - Node Awake
2017-10-23 09:01:16.438 Detail,
2017-10-23 09:01:16.440 Info, Node010, Sending (WakeUp) message (Callback ID=0xff, Expected Reply=0x13) - WakeUpCmd_NoMoreInformation (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x84, 0x08, 0x25, 0xff, 0xbb
2017-10-23 09:01:16.450 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-10-23 09:01:16.452 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2017-10-23 09:01:16.467 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0xff, 0x00, 0x00, 0x02, 0x16
2017-10-23 09:01:16.469 Detail, Node010, ZW_SEND_DATA Request with callback ID 0xff received (expected 0xff)
2017-10-23 09:01:16.471 Info, Node010, Request RTT 28 Average Request RTT 27
2017-10-23 09:01:16.473 Info, Node010, Node 10 has been marked as asleep
2017-10-23 09:01:16.475 Detail, Expected callbackId was received
2017-10-23 09:01:16.476 Detail, Expected reply was received
2017-10-23 09:01:16.478 Detail, Message transaction complete
2017-10-23 09:01:16.480 Detail,
2017-10-23 09:01:16.482 Detail, Node010, Removing current message
2017-10-23 09:01:16.484 Detail, Node010, Notification: Notification - Node Asleep
2017-10-23 09:01:17.141 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x04, 0x03, 0x03, 0x20, 0x01, 0x00, 0xd7
2017-10-23 09:01:18.648 Detail,
2017-10-23 09:01:18.649 Info, Node003, Received Basic set from node 3: level=0. Sending event notification.
2017-10-23 09:01:18.652 Detail, Node003, Notification: NodeEvent
2017-10-23 09:01:18.702 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x04, 0x03, 0x03, 0x20, 0x01, 0x00, 0xd7
2017-10-23 09:01:18.721 Detail,
2017-10-23 09:01:18.724 Info, Node003, Received Basic set from node 3: level=0. Sending event notification.
2017-10-23 09:01:18.726 Detail, Node003, Notification: NodeEvent
2017-10-23 09:01:18.773 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x20, 0x01, 0x00, 0xd3
2017-10-23 09:01:18.775 Detail,
2017-10-23 09:01:18.777 Info, Node003, Received Basic set from node 3: level=0. Sending event notification.
2017-10-23 09:01:18.779 Detail, Node003, Notification: NodeEvent
2017-10-23 09:01:18.820 Detail, Node003, Received: 0x01, 0x10, 0x00, 0x04, 0x04, 0x03, 0x0a, 0x71, 0x05, 0x07, 0x00, 0x00, 0xff, 0x07, 0x02, 0x00, 0x00, 0x6f
2017-10-23 09:01:18.822 Detail,
2017-10-23 09:01:18.824 Info, Node003, Received Alarm report: type=7, level=0, sensorSrcID=0, type:Burglar event:2, status=255
2017-10-23 09:01:18.845 Detail, Node003, Refreshed Value: old value=7, new value=7, type=byte
2017-10-23 09:01:18.847 Detail, Node003, Changes to this value are not verified
2017-10-23 09:01:18.849 Detail, Node003, Refreshed Value: old value=255, new value=0, type=byte
2017-10-23 09:01:18.851 Detail, Node003, Changes to this value are not verified
2017-10-23 09:01:18.853 Detail, Node003, Refreshed Value: old value=0, new value=0, type=byte
2017-10-23 09:01:18.855 Detail, Node003, Changes to this value are not verified
2017-10-23 09:01:18.856 Detail, Node003, Refreshed Value: old value=2, new value=2, type=byte
2017-10-23 09:01:18.858 Detail, Node003, Changes to this value are not verified
2017-10-23 09:01:18.861 Detail, Node003, Notification: ValueChanged
2017-10-23 09:01:19.076 Detail, Node003, Notification: ValueChanged
2017-10-23 09:01:19.418 Detail, Node003, Notification: ValueChanged
2017-10-23 09:01:19.711 Detail, Node003, Notification: ValueChanged
