I have a Shelly double relay that is recognized by HA. One of the two lights randomly turn on. I have checked and double checked and there is no automation, script, or blueprint that is associated with it. When I look at the activity log of this device is see the following:
“Back Lights turned on triggered by action Home Assistant Core Integration: Generic turn on”
You have an automation (or, more likely, a blueprint) which uses homeassistant.turn_on (or homeassistant.toggle).
Find the automation which is using it and check the targets. Most probably the affected light has an area or label which is being targeted in the automation.
