Lightwave local setup
Good morning all,
I have now got lightwave working correctly with HA but now i want to go the one step further and make it all local. Has anyone succeeded in doing this. I have a lightwave hub 2 and a selection of both old and new generation equpment including the honeywell TRV’s etc. I understand alot of this can be done with homekit but only if it is gen 2 products. I have read all the API stuff on line but wondered if anyone has managed to get a full working system. This is just stage 1 as i also have samsung smartthings and other stuff i will need to make local.
Thanks in advance for any advice.
Edd
Anyone out there ???
I’d be interested in this too…
I’m having difficulty getting LWRF working at all currently.
Any tips?
I’ve added the YAML config (as per the documentation) and added 2 lightswitches, which are appearing as entities and added these to the dashboard.
I’ve tried pairing with the local LWRF hub by running echo -ne "100,!Fp." | nc -u 192.168.1.44 9760 from the terminal to pair with the hub, but to no avail.
It’s a gen2 LWRF hub.
Super grateful for any suggestions. I’m brand new to HA
The use of lightwave TRVs is documented here:
To get initial pairing to work, the method I have used is restart HA, then keep pressing the pairing button on the hub until HA has rebooted.
I have a Gen 1 Hub.
