LightwaveRF Lights Generation 1 Home Assistant - Custom Component - Setup
Also pairing your HA to your LW hub, you have to open a terminal in HA, and enter the follow command
echo -ne ‘100,!F*p.’ | nc -u 192.168.1.12 9760
replace the ip with you local ip for you lw hub
once you send the command, the green light should be flashing on your lw hub, you should quickly press the link button on your hub.
If you are having problems with this, you may have too many paired smart phones/tablets etc paired to your hub. To resolve, open your LW app on phone/tablet, go to settings, then Lightwave Link Settings, then Authorised devices. Here it will show you how many devices are authorised to control your LW system, if i recall max is 8 or 10 devices, you can de-authorise all devices and then login again on devices that matter, including pairing you HA system to LW hub.
cheers fella ,
quick and def very informative :+1:t3: :+1:t3:
all good found me devices :grinning:
hi so maybe a dung question ,but not being able to run that ,
have i got to log in under core or something to run it ?
using terminal just shows the home assistant run screen ending with
observer URL
Typing after and pressing return dosent seem to do anything
cheers fella
Does this integration also work with the Lightwave LW380 plug-in sockets and the LW830 3000W Inline Relays?
hey,
an thank you in advance, is it possible to setup lightwave rf with virtual box running on a mac ?
thank you
resurrecting an old thread here, sorry!!!
Have SSH’d into my HA (on RPi) and am trying to send the pairing command from HA to my Gen 1 LW Link, but I’m getting the following error:
[core-ssh ~]$ echo -ne ‘100,!F*p.’ | nc -u 192.168.1.139 9760
-bash: !F: event not found
Any help appreciated.
@garmcqui - Your quotes are incorrect use this style instead ’
echo -ne '100,!F*p.' | nc -u 192.168.1.139 9760
Thank you!
Thought it might be worth mentioning my solution to the Lightwave “problem”.
When the Gen 1 sockets and switches came out there was also a RF remote which could control up to 16 switches. Long since discontinued, of course, but you can still get them on Ebay for about £10.00. (This is the JSJSLW100 - not the smaller remote that came with the smart plugs.)
If you pair this with the switches and sockets, you can the use it to “train” an RF blaster such as the Broadlink RM4 Pro. No need for the hub any more. My Broadlink covers the whole house (three floors) very effectively.
