LILYGO Internet POE board integration
Has anyone tried this board ??
“LILYGO TTGO T-Internet-POE ESP32-WROOM LAN8720A”
I have it at home with a programming card, but I can’t load FW there. The board must be started in flash mode before recording. It is necessary to press the Reset button, hold down and then briefly the BOT button. Then I managed to load the program, but it doesn’t work.
The board will not connect to Wifi. I have such a hunch that there could be a problem in Device Type, but unfortunately nowhere can I find even a mention of what to set there. According to the ESPHome website, the board should be supported, for example, to be seen in the ethernet settings section.
Did anyone manage to set it up ??
There does not appear to be a supported board_type: https://docs.platformio.org/en/latest/platforms/espressif32.html#ttgo
Though it is working with Tasmota, https://github.com/arendst/Tasmota/issues/9345#issuecomment-763366383
So somehow I was hoping that the board is supported when the ethernet settings are supported on it.
Well in that case I reckon it is supported. It’s just not on the list. What are you using as the board type in the core configuration?
The problem was solved by using the hints from Discord. I used “ESPEasyFlasher” which was inappropriate. As well as the second application. When using “ESPHome-Flasher” everything went well.
I’d still like to know what you used as the board type, since it isn’t listed on platformio.
Hi, what this board should be in the device list?
