Lilygo T-display YAML code
Does anyone has a very simple working YAML code to start with Lilygo T-display.
I received my unit and I would like to load, using Esphome, a very basic code to start learning.
For example a code that would display a Home Assistant entity and that I can turn ON/Off using the button on the device.
there are a bunch of different version… T-Display S3, T-Display-s3-OLED. For the plain T-Display, here is mine to get you started:
esphome:
  friendly_name: 1.9 case 1
esp32:
  board: esp32dev
  framework:
    type: arduino
deep_sleep:
 # run_duration: 5min
  esp32_ext1_wakeup:
    mode: ALL_LOW
    pins:
      - number: 0
        allow_other_uses: true
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "****"
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Web-3D6B80"
    password: "GD2UrQDWBaz4"
# Include custom fonts
font:
  - file: "gfonts://Roboto"
 - platform: adc
   name: "19-case-1 Battery Raw"
   pin: 34
   attenuation: 11db
   update_interval: 10s
   internal: false
   entity_category: diagnostic
   unit_of_measurement: '%'
   lambda: |-
      return ((id(VCC).state / 2.47) * 100);
binary_sensor:
  - platform: homeassistant
    entity_id: binary_sensor.kitchen_fp2_presence_sensor_2
    entity_id: binary_sensor.kitchen_hue_motion_sensor_motion
    entity_id: binary_sensor.kitchen_motions
    entity_id: binary_sensor.living_room_fp2_presence_sensor_3
  - platform: gpio
    pin:
      number: GPIO0
      inverted: true
      mode:
        input: true
        pullup: true
    name: "19-case-1 Button 1"
    on_click:
      then:
   #     - light.turn_on: back_light
  - platform: gpio
    pin:
      number: GPIO35
      inverted: true
    name: "19-case-1 Button 2"
    on_click:
      then:
        - deep_sleep.enter
  #      - light.turn_off: back_light
output:
  - platform: ledc
    pin: 4
light:
  - platform: monochromatic
    output: gpio_04_backlight_pwm
    name: "Display Backlight"
    restore_mode: ALWAYS_ON
# Define colors
color:
  - id: color_text
    red: 100%
    green: 0%
    blue: 0%
    white: 0%
# Pins for Board
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO19
# render on the screen.
display:
  - platform: st7789v
    cs_pin: GPIO5
    dc_pin: GPIO16
    reset_pin: GPIO23
    backlight_pin: no
    model: TTGO TDisplay 135x240
    update_interval: 1s
    rotation: 90°
    lambda: |-
      if (id(kitchenfp2).state) {
        it.print(0, 0, id(roboto), color_text,TextAlign::TOP_LEFT, "K FP2");
      } else {
        it.print(0, 0, id(roboto), color_text,TextAlign::TOP_LEFT, "");
      if (id(kitchenhue).state) {
        it.print(it.get_width(), 0, id(roboto), color_text,TextAlign::TOP_RIGHT, "K M");
      } else {
        it.print(it.get_width(), 0, id(roboto), color_text,TextAlign::TOP_RIGHT,"");
      if (id(motiongroup).state) {
      it.print(0, 135, id(roboto), color_text,TextAlign::BOTTOM_LEFT,"K G");
      } else {
          it.print(0, 135, id(roboto), color_text,TextAlign::BOTTOM_LEFT,"");
      if (id(lrfp2).state) {
      it.print(it.get_width(), 135, id(roboto), color_text,TextAlign::BOTTOM_RIGHT, "LR FP2");
      } else {
          it.print(it.get_width(), 135, id(roboto), color_text,TextAlign::BOTTOM_RIGHT, "");
      it.printf(it.get_width()/2, it.get_height()/2, id(roboto), color_text,TextAlign::CENTER, "%.1f", id(VCC).state / 2.47 * 100);
captive_portal:
Thank you very much, this look very good to get me started
I’ve been trying to figure out how to load above code into my ESP32 to get started with ESPhome and Home assistant but searching has not helped as to how to go about it.
I’m successfully running Home Assistant in Docker. ESPHome has been installed and ESP32 connects and I’m able to able to “PREPARE DEVICE FOR FIRST USE” in web interface then successfully “Configure Wi-Fi”. After this, Home Assistant notifies me of new device which then I configure and everything seems to work fine. But after this I have no clue as to where to go from here for custom code like the one above. Can someone please point me in the right direction. I been at this for days and just can’t figure it out.
It should be visible in the ESP-Home addon of Home Assistant.
Do you have that installed?
I gave up running HA in Docker. This was causing me all sorts of issues due to software limitations. I’m running it in a virtual machine now and ESPHome works as it should.
a bit late, but: If everything worked fine, you can, from the notification in HASS about the new device, install (adopt, or something similar). As a result a yaml file containing the standard name of the device is created. You can edit this with the studio code server add-on, or in ESPHome Builder (this is the current name of the add-on). During editing, you enter the code, save, then “install”
