Lilygo T-Encoder Pro config for ESP-Home
After spending a couple of days messing with this, I finally got the correct configuration for the Lilygo T-Encoder Pro.
I haven’t played with the touchscreen yet, so that would be another thing to add.
Hopefully this gives others a head-start on some projects!
esphome:
  friendly_name: T-Encoder Pro
  min_version: 2024.6.0
  name_add_mac_suffix: false
  platformio_options:
    board_build.flash_mode: dio
    board_build.esp-idf.memory_type: qio_opi
esp32:
  board: esp32-s3-devkitc-1
  variant: esp32s3
  framework:
    type: esp-idf
  flash_size: 16MB
# Enable PSRAM
psram:
  mode: octal
  speed: 80MHz
# Add generic ota, api, logging, etc ...
# Configure the Quad SPI bus
spi:
  type: quad
  clk_pin: GPIO12
  data_pins: [GPIO11, GPIO13, GPIO7, GPIO14]
# Display configuration
display:
  - platform: qspi_dbi
    dimensions:
      width: 390
      height: 390
    model: CUSTOM
    cs_pin: GPIO10
    reset_pin: GPIO4
    enable_pin: GPIO3
    rotation: 0
    invert_colors: false
    draw_from_origin: true
    auto_clear_enabled: false
    update_interval: never
    init_sequence:
      - [0x01]  # Software Reset
      - delay 200ms
      - [0x11]  # Sleep Out
      - delay 120ms
      - [0x13]  # Normal Display Mode On
      - [0x20]  # Display Inversion Off
      - [0x3A, 0x05] # Interface Pixel Format 16bit/pixel
      - [0x29]  # Display On
      - [0x53, 0x28]  # Brightness Control On and Display Dimming On
      - [0x51, 0x00]  # Brightness Adjustment
      # High contrast mode (Sunlight Readability Enhancement)
      - [0x58, 0x00]  # High Contrast Mode Off
      # - [0x58, 0x05]  # High Contrast Mode Low
      # - [0x58, 0x06]  # High Contrast Mode Med
      # - [0x58, 0x07]  # High Contrast Mode High
      - delay 10ms
font:
  - file: "gfonts://Roboto"
lvgl:
  style_definitions:
    - id: black_background
      bg_color: 0x000000
      bg_opa: 100%  # Fully opaque
  pages:
    - id: main_page
      styles: black_background
      widgets:
        - label:
            text: "78"
            x: 120
            y: 137
            text_align: center
            text_color: 0xAAAAAA
            text_font: my_font
  - platform: rotary_encoder
    pin_a: 1
    pin_b: 2
    on_clockwise:
      - logger.log: "Turned Clockwise"
    on_anticlockwise:
      - logger.log: "Turned Anti Clockwise"
binary_sensor:
  - platform: gpio
    pin:
      number: 0
    on_press:
      - logger.log: 'Button Pressed!'
      - if:
          condition:
            rtttl.is_playing
          then:
            - logger.log: 'Playback stopping!'
            - rtttl.stop
          else:
            - logger.log: 'Playing starting!'
            - rtttl.play: 'star_wars:d=16,o=5,b=100:4e,4e,4e,8c,p,g,4e,8c,p,g,4e,4p,4b,4b,4b,8c6,p,g,4d#,8c,p,g,4e,8p'
output:
  - platform: ledc
    pin: 17
rtttl:
  output: buzzer
  gain: 60%
Were you able to get the touchscreen working?
No, I haven’t. The touchscreen isn’t really necessary for my use case.
Here’s a simple CHSC5816 touch component for the T-Encoder Pro that we whipped up together with a friend.
We’ve done only minimal testing, but the component detects touches just fine and seems to be stable. There’s a sample ESPHome yaml file included too.
Thank you so much for making this! Been testing it out a bit. I am not sure if I am doing something wrong, but I always get the “dir” as 0 no matter which direction I am swiping.
[18:42:16][D][chsc5816.touchscreen:128]: CHSC5816 touch swipe at: 209 233 with dir 0
[18:42:16][D][chsc5816.touchscreen:128]: CHSC5816 touch swipe at: 207 231 with dir 0
[18:42:16][D][chsc5816.touchscreen:128]: CHSC5816 touch swipe at: 192 190 with dir 0
[18:42:16][D][chsc5816.touchscreen:128]: CHSC5816 touch swipe at: 185 97 with dir 0
It also does not seem to ever register the ESP_LOGD(TAG, "CHSC5816 touch point at: %d %d", x, y); on line 131. This may be because I have fat fingers… But wasn’t sure if you ever got that line to output.
