When trying stuff with esphome a lot of times I make my HA crash(HA Yellow with 4GB of RAM)
so it’s not the hardware, but the esphome process.
What happens is that I’m working, start installing, (manual/wifi/com) and sometimes something is wrong, or the com connection breaks so I click stop.
The the background the compiling continuous, (I think). Sometimes this happens like 4 times.
then ESPHome is building the same binary for the same device 4 times and home assistant crashses.
there is nothing in the log, I checked and the last 5 minutes aren’t stored. the is because of the whole ssd wearout thing.(different issue, and not one I’m having)
now there is compile_process_limit
which limits the number op cpu’s
but I’d rather have an option which checks if esphome is already compiling and if so stop the current process or just wait.
Als also the stop button should not just close the dialog. I should stop the process too.
